Installation & Licensing
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Cannot initialze License manager: ADLM: startup failed
- Highlight
- Email to a Friend
Running Autodesk Simulation and other Autodesk products on same PC.
Added INCREMENT of new license to my license file but Simulation does not start. Only strange thing is that I get "?\?F?" at the end of Flexlm log file.
Re: Cannot initialze License manager: ADLM: startup failed
- Highlight
- Email to a Friend
You may have appended the file wrong. Post your status enquiry here and I will check.
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!Re: Cannot initialze License manager: ADLM: startup failed
- Highlight
- Email to a Friend
Hi Travis,
Please see attached.
Thanks for your help
BR
MH
- Highlight
- Email to a Friend
That does seem odd about that log file.
Can you copy the contents of your .LIC file in a PM to me so that I can check its consistency? I don't want you to post that sensitive information to the open forum.
Thanks.
- Highlight
- Email to a Friend
I received your PM, but you need to post your LIC file in it. Thanks.
- Highlight
- Email to a Friend
Hi Travis,
Just got this from Autodesk:
Dear MH:
Thank you for your response.
Kindly note that ASPRO stands for Autodesk Simulation Multiphysics 2013.
We have verified the license file and it's correct.
We kndly ask you to try to activate the product once more with the license file provided by us.
You can update the status of this case, attach files or provide additional information by replying to this email. Please let us know if you have additional feedback regarding the way your case is being handled.
Did you know that Autodesk experts are now monitoring and responding in the Install & Licensing Autodesk Discussion Forum? For fast answers to your questions from Autodesk and community experts, please visit the forum by clicking here.
Thank you for contacting Autodesk.
Do you still want to see the license file?
BR
MH
- Highlight
- Email to a Friend
Nah, if they say it is fine then it is probably fine. What error are you getting when you try to launch your 2013 product?
I noticed your license manager is still 11.9. You need to be running 11.10 for the 2013 product line.
- Highlight
- Email to a Friend
Hi Travis,
I have updated the FlexLM tools to:
FLEXnet Licensing (v11.10.0.3 build 96515 x64_n6) started on SELAP367 (IBM PC) (4/10/2012)
But still get this:
Cannot initialize license manager: ADLM: startup Failes
Suggested Solutions:
1. Verify the license manager is running, and ensure connectivity.
2. Verify that license has not expired.
3.Verify that the license is for the current version of Autodesk Simulation CFD.
Status Enquiry:
Users of 85942ASPRO_2013_0F: (Total of 1 licenses issued; Total of 0 licenses in use)
Diagnostics:
"85942ASPRO_2013_0F" v1.000, vendor: adskflex License server: SELAP367 floating license starts: 1-jan-1990, expires: 02-jun-2013 Requests from the same USER/HOST do not consume a new license
This license can be checked out
Any Idea what I should do?
BR
MH
- Highlight
- Email to a Friend
Per your status enquiry, your NLM is running fine. Can you ping the server? Does it get an IPv4 address or IPv6? If it is an IPv6, see my IPv6 fix in my signature link.
Also check for port blocking. Ports 2080 and 27000 need to be open. You can check this with Internet Explorer (not 3rd party browser) by clicking these links for your NLM:
You should get this response for each:
Wê-60Wê-60Wê-60Wê-60Wê-60Wê-60
You might also set system environment variables for ADSKFLEX_LICENSE_FILE @SELAP367 as well as FLEXLM_TIMEOUT 1000000.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
- Highlight
- Email to a Friend
I had the same problem (and message) with Simulation CFD 2013, but i got suspicious because it seemed to be a local failure according the message, but I pointed to another machine as a license server.
After consulting another user (already running the application) and comparing our registry settings, I changed the following key: \HKLM\software\Autodesk Simulation CFD\13.0\Locale. It's value was du-NL (probably due to the language setting of the license agreement during the installation). I changed it to en-US, and voila, it worked, see the attachement. So in the end my license server was not the problem.
I hope this is working for you too.
