Show only
Search instead for
I'm Spanish so I hope my poor English will be understood. I did have two different problems installing the programme. I have no idea whether they're related or not. At the begining of the installation process an error ocurred with Autodesk Design Review 2012. This happened the hundred times I tried the whole process. I installed the Inventor without this one and everything went all right. Another problem show up later while trying to activate the product. I can only use the 30 days trial version. When I click on CONTINUE after acepting the terms of use and all that stuff the window to activate the licence showed up compleatly white. Another time I tried, the window had only two points. I can not activate it. I have tried so many diferrent things. I do not know what else to do.
I've found the solution in another post. It did solve some other problems I had on the computer. Thanks so much to the solution you gave me because I found this post trying the options of the webpage. The problem was McAfee. I didn't even have the McAfee anti-virus intalled, because I uninstalled it a long time ago. Despite everything, I still had some McAfee stuff on my latop. Here is the link: http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/m-p/4789571
