• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    bkballa
    Accepted Solution
    Cannot Uninstall Civil 3D 2011
    1203 Views, 2 Replies
    01-13-2011 02:46 AM
    My Civil 3D 2011 would not start. It just blinks and disappears.
    I tried to repair/reinstall Civil 3D. During the middle of the session, it gives an error and rolls back the "installation. Then I tried uninstalling 3D to the same effect
    I searched the blogs for solution. One of them said I need to uninstall Materials Base Library, Materials Library IN THAT ORDER and uninstall Civil 3D. Still the same error message crops up. And in this process my AutoCad 2011 also stopped working.
    Now one of the forum answers told me to uninstall ALL autodesk products including materials library and do a clean install. This time also I decided to bite the bullet. I was able to uninstall ALL the autodesk products except, yes you guessed it, Civil 3D.
    Now Please tell me how to UNINSTALL/REPAIR/REINSTALL Civil 3D 2011. Thanks.
    Biswa
    PS: And yes, I did uninstall my .Net framework and reinstalled it and updated it using Windows update. By the way I run Civil 3D on 32-bit Windows 7 Ultimate.
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Cannot Uninstall Civil 3D 2011
    01-13-2011 06:06 PM in reply to: bkballa
    Use the Microsoft Installer Cleanup Utility to remove your Civil 3D.  Then manually delete the Civil files under Program Files.  Your initial problem may have been caused by a corrupt CascadeInfo.cas file, but you are beyond that now.
    For more detailed information about the CascadeInfo.cas file, please refer to the Autodesk Support Knowledge Base article found here:
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=13894457&siteID=123112
    Installation problems may be resolved using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    bkballa
    01-25-2011 06:02 AM in reply to: TravisNave
    Thanks.
    The microsoft uninstaller utility worked like a charm. I was aware of the utility, but was reluctant to use it as microsoft "retired" it (presumbly for MS-Office related problems).
    Anyways problem solved :smileyhappy: I did reinstall Civil 3D 2011, however I decided not to reinstall AutoCAD 2011 as 3D has bult-in AutoCAD.
    Thanks once again.
    Biswa
