Installation & Licensing
Cannot Install Revit 2013. Something called Windows Register Server stopped.
7 REPLIES 7
Message 1 of 8
xlwan
2713 Views, 7 Replies
I think the problem lies around here (pasted below) in the log.
Anyone has any idea why?
I have tried reinstalling it three times, same problem all the time.
Some kind of error happens during registering a dll.
I have also tried uninstalling Revit 2011 which I had installed and everything that uses autodesk shared libs, basically removed everything autodesk.
Please help!
MSI (s) (E4:60) [17:39:35:946]: Note: 1: 1722 2: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C 3: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\ 4: regsvr32.exe /s "RBCTMdbEditX.dll"
CustomAction win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C returned actual error code -1073740791 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (E4:60) [22:37:43:808]: Product: Revit Architecture 2013 - - Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor.  Action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C, location: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\, command: regsvr32.exe /s "RBCTMdbEditX.dll"
Action ended 22:37:43: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C. Return value 3.
Action ended 22:37:43: INSTALL. Return value 3.
7 REPLIES 7
Message 2 of 8
DannyHubbard
in reply to: xlwan
In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again.
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 3 of 8
xlwan
in reply to: DannyHubbard
Thanks for the reply
What should I rename it to? anything?
Anyway I'll try rename it to RBCTMdbEditX.dll.bak and see what happens.
Message 4 of 8
xlwan
Unfortunately that didn't work...
still the same problem.
Is there any way that I can bypass the registration of this dll and manually register it at a later time?
Message 5 of 8
FRFR1426
in reply to: xlwan
Same problem here with Revit MEP 2013. Error 1722, action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C
Revit is installed, but It fail to start. I see the splash screen, then boom.
Lost one day with this. And this stupid installer detect that Revit MEP 2013 is installed, so I need to delete it, I'm not able to desinstall it with the control panel.
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 6 of 8
FRFR1426
in reply to: xlwan
I've deleted the whole directory (C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAcces), relaunch the installed and It worked. 10 hours for installing a single program... I had to write a special program in order to remove some keys created in the registry by Revit...
Maxence DELANNOY
Manager
http://wiip.fr
Message 7 of 8
xlwan
in reply to: FRFR1426
i tired but not working for me. I had this problem twice, both solved by reinstalling windows then install revit right away before anything else...
Message 8 of 8
D.M.Babu
in reply to: xlwan
Hi ,
I am experiencing the same kind of error for Revit Architecture 2012,i am unable reinstall the Application also.
Kindly help us to resolve it.
Operating system:Win7,64bit
Revit  2012,Network License.
Thank you in Advance,
D.M.Babu
Administrator Productivity
