Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Cannot Install Revit 2013. Something called Windows Register Server stopped.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I think the problem lies around here (pasted below) in the log.
Anyone has any idea why?
I have tried reinstalling it three times, same problem all the time.
Some kind of error happens during registering a dll.
I have also tried uninstalling Revit 2011 which I had installed and everything that uses autodesk shared libs, basically removed everything autodesk.
Please help!
MSI (s) (E4:60) [17:39:35:946]: Note: 1: 1722 2: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_
CustomAction win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_
MSI (s) (E4:60) [22:37:43:808]: Product: Revit Architecture 2013 - - Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_
Action ended 22:37:43: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_
Action ended 22:37:43: INSTALL. Return value 3.
Re: Cannot Install Revit 2013. Something called Windows Register Server stopped.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again.
Danny
Danny Hubbard
QA Analyst
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
DannyHubbard wrote:select the file "RBCTMdbEditX.dll", right click and choose Rename.
Thanks for the reply
What should I rename it to? anything?
Anyway I'll try rename it to RBCTMdbEditX.dll.bak and see what happens.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Unfortunately that didn't work...
still the same problem.
Is there any way that I can bypass the registration of this dll and manually register it at a later time?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Same problem here with Revit MEP 2013. Error 1722, action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_
Revit is installed, but It fail to start. I see the splash screen, then boom.
Lost one day with this. And this stupid installer detect that Revit MEP 2013 is installed, so I need to delete it, I'm not able to desinstall it with the control panel.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've deleted the whole directory (C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAcces), relaunch the installed and It worked. 10 hours for installing a single program... I had to write a special program in order to remove some keys created in the registry by Revit...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
