I am using a 2011 iMac with 8GB Ram (7GB devoted to Windows 7 running on Parallels Desktop). My processor is a 2.5 GHz Intel Core i5. The system requirements for C3D 2010 recommend a 3 GHz processor or faster, 7GB disk space for installation, 2-4GB RAM for normal use. I have tried installing the product but keep getting failing results. I have increased the RAM designated to Parallels up to 7GB for install but still having problems. I have not found anyone else who has tried to run ACAD on parallels, but that should not be the problem. I have talked with many people who are running larger software than ACAD. I have uninstalled McAfee which seemed to help others with the same failure errors but I am still unable to install. Any help would be appreciated. My failure log is below.
2011/10/10:19:54:37AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:19:55:22AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:19:55:48AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/10:20:20:03AdministratorJOEPATTERSOD97BInstallMicrosoft Visual C++ 2005 Redistributable (x86)Succeeded
2011/10/10:20:20:18AdministratorJOEPATTERSOD97BInstallMicrosoft Visual C++ 2008 Redistributable (x86)Succeeded
2011/10/10:20:20:18AdministratorJOEPATTERSOD97BUninstall{450063AA-643B-417C-8CF5-405BA3F4EF40}Failed
2011/10/10:20:20:18AdministratorJOEPATTERSOD97BUninstall{02A00C13-555A-4B8A-B53B-1D02FFF5EEAF}Failed
2011/10/10:20:20:18AdministratorJOEPATTERSOD97BUninstall{106EC844-9F5E-4B72-BB3B-1E47D274A944}Failed
2011/10/10:20:20:18AdministratorJOEPATTERSOD97BUninstall{FACF203E-0F4D-489A-B80C-D185253C8FCB}Failed
2011/10/10:20:20:28AdministratorJOEPATTERSOD97BInstallAutodesk Design Review 2010Succeeded
2011/10/10:20:20:38AdministratorJOEPATTERSOD97BInstallVBASucceeded
2011/10/10:20:21:01AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:20:21:04AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/10:20:21:09AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/10:20:24:36AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:20:24:40AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/10:20:24:44AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/10:20:25:12AdministratorJOEPATTERSOD97BInstallMicrosoft WSE 3.0 RuntimeSucceeded
2011/10/10:20:25:12AdministratorJOEPATTERSOD97BInstallDirectX 9.0 Runtime March 2008FailedFailure is ignored, Result=2
2011/10/10:20:25:21AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:20:25:24AdministratorJOEPATTERSOD97BInstallDWG TrueView 2010FailedFailure is ignored, Result=1603
2011/10/10:20:25:31AdministratorJOEPATTERSOD97BInstallAutodesk Vault 2010 (Client)FailedInstallation aborted, Result=1603
2011/10/10:20:28:34AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:20:28:38AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/10:20:28:43AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/10:20:33:59AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:20:34:44AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:20:35:10AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/10:20:54:12AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/10:20:56:13AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:20:56:57AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/10:20:57:23AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/10:21:00:52AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:21:00:57AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/10:21:01:01AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/10:21:08:52AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/10:21:08:57AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/10:21:09:01AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/10:21:09:57AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:09:34:17AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:09:35:02AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:09:35:29AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:09:38:51AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/11:09:38:59AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/11:09:39:03AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/11:09:39:04AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:09:27AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:10:56AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:11:46AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:13:56AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:17:08AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:18:37AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:19:02AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:19:02AdministratorJOEPATTERSOD97BAn instance of setup is already running. Only one instance of setup can run at a time.2011/10/11:10:19:13AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:19:28AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:23:26AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/11:10:23:33AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/11:10:23:38AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/11:10:28:44AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:37:17AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:38:47AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:10:39:36AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:10:45:02AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/11:10:45:09AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/11:10:45:15AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/11:10:45:19AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:13:12:12AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:13:13:50AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2011/10/11:13:15:05AdministratorJOEPATTERSOD97B=== Setup ended ===
2011/10/11:13:18:11AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2011/10/11:13:18:17AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2011/10/11:13:18:28AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
2011/10/11:13:20:32AdministratorJOEPATTERSOD97B=== Setup ended ===
2013/5/24:07:27:54AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2013/5/24:07:28:39AdministratorJOEPATTERSOD97B=== Setup started on JOEPATTERSOD97B by Administrator ===
2013/5/24:07:29:10AdministratorJOEPATTERSOD97B=== Setup ended ===
2013/5/24:07:36:09AdministratorJOEPATTERSOD97BInstallDirectX 9.0 RuntimeSucceeded
2013/5/24:07:36:15AdministratorJOEPATTERSOD97BInstallMicrosoft Visual Basic Power Packs 3.0Succeeded
2013/5/24:07:36:21AdministratorJOEPATTERSOD97BInstallAutoCAD Civil 3D 2010FailedInstallation aborted, Result=1603
