Installation & Licensing
Cannot Install AutoCAD 2012 Service Pack 2
9 REPLIES 9
Message 1 of 10
coopdetat
2159 Views, 9 Replies
I tried to install this service pack (in both 32-bit and 64-bit versions) and I get an installation error for both of them: "the service pack could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct service pack for the product."
I tried installing it (both 32-bit and 64-bit) without AutoCAD open, with Civil 3D as AutoCAD open, with Civil 3D open, and in each case I get the same error. I there a special civil 3-D service pack 2?
And, yes, I have administrator privileges on this machine and am explicitly running the install as administrator.
[Product Information Properties] Tuesday, June 12, 2012 11:08:35 AM
License name: AutoCAD Civil 3D 2012
Computer host name: WTR124
Product serial number: 392-########
Product key: #####
License type: Standalone - Locked
License expiration date: None
License behavior: Permanent
License usage type: Commercial
License ID: CIV3D_F_S
---------------------------------------------Signature--------------------------------------------
Civil Design Professional Since 1983 (Intergraph), AutoCAD since 1989
Windows 10 Pro 64-bit Intel﴾R﴿ Core﴾TM﴿ i9-12900KF CPU 3.19GHz; 32 GB DDR4 4266 Dual Channel RAM
nVidia Quadro RTX 4000; AutoCAD Civil 3D 2023.2.1 Update
9 REPLIES 9
Message 2 of 10
DarrenP
in reply to: coopdetat
that service pack is for autocad not Civil 3d
DarrenP
Message 3 of 10
coopdetat
P.S. Live Update in the Communication Center says "Your Product is Up To Date"
Product Version F.107.0.0.AutoCAD Civil 3D 2012 SP1
Is the service pack not applicable to Civil 3D?
Message 4 of 10
DarrenP
no its not
civil 3d has its own service packs
DarrenP
Message 5 of 10
coopdetat
in reply to: DarrenP
Not so vertical then is it? Sort of parallel universe kinda thing.  I have C3D 2013 but like a little stabilization of a version before going to the next.  So do they fix some problems as well as create new ones in C3D 2013 or do they just create new problems?
Message 6 of 10
DarrenP
usually both
DarrenP
Message 7 of 10
coopdetat
Your response was brief but very good. it prompted me think critically again and quit QQ'ing.  I've been holding off going to C3D 2013 for an invalid reason.  Everybody else here is using C3D 2009.  I didn't want to change file formats on them... but I already have.  I work in 2010 format and they in 2007.  I'm the office "pilot program" for new versions so...
Thanks!  I'm going to install C3D 2013.  It is best to be using the latest version when the others make the leap to what I'm using.
Message 8 of 10
DarrenP
with every release of any of the autodesk products they all introduce new features those new features usually break a feature that worked in the previous version of the software which some of the new features can usually break by a service pack
DarrenP
Message 9 of 10
coopdetat
I was looking for the VBA download for 2012 and 13 at home and I also found that both Service Pack 1 and 2 were listed there in the available updates.  There was no separate service pack 1 for Civil 3D 2012 that I saw.  I can't remember when or where I got service pack 1 but I have it installed and it appears that service pack 1 for "AutoCAD" was also applicable to "AutoCAD C3D".
It would help if Autodesk would explicitly identify the products the service packs are applicable to so that users like me can be sure of which service packs are applicable.  Without the information I cannot be sure whether I am experiencing an error or trying to instal a service pack that does not apply.
Autodesk, can you clear this up?
Message 10 of 10
DarrenP
the civil 3d 2012 service pack 1 is here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18133124&linkID=9240698
DarrenP
Administrator Productivity
