Installation & Licensing
Can't uninstall Revit 2012
6 REPLIES 6
dgt.mantis
2804 Views, 6 Replies
I am trying to unistall Revit 2012 and I cannot access the uninstaller.  I go to add/remove programs and click uninstall and nothing happens.  I briefly see the windows circle 'thinking' but then nothing.
Furthermore, I have tried to open the program and it hangs on the splash screen and won't open.  I have followed all directions from this post:
http://revitclinic.typepad.com/my_weblog/2011/05/revit-2012-hangs-at-splash-screen-or-crashes-with-u...
and it still hangs up and must be forced to close.
I don't want to get the software functioning anymore.  I just want it gone.  Any help would be GREATLY appreciated.
Thanks!
6 REPLIES 6
t_gaisf
in reply to: dgt.mantis
This link might help:
How to remove all Autodesk products from a Windows system
Franz Gaisbauer
dgt.mantis
in reply to: t_gaisf
Thank you for the replay....however that link definately does not help.
The link you provided basically walks you through Add/Remove programs.  Did you not see the first part of my post?  The uninstaller will not even start when I go to Add/Remove programs.   The program is listed but nothing happens when I double-click it, right click and select uninstall or select uninstall from the menu at the top.
I need an alternative method to remove the program or fix the reason why it is not accessable through Add/Remove programs.
TravisNave
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
For all other installation problems on Windows XP SP2 or below consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
dgt.mantis
in reply to: TravisNave
Thank you Travis.
The first link to the Microsoft Fixit article worked.  It was successfully uninstalled.
Thanks again.
TravisNave
Excellent!  Happy to help!
Autodesk Forums:
True, that microsoft uninstall tool removes  any remaining of revit, the only thing is that we have to scroll down since the revit program is not listed under the Autodesk apps, its listed under Revit 2014
http://easycomputertutorial.com/revit-2014-wont-open/
Administrator Productivity
