Jonathan -
That's a new one. Okay, it looks like the problem starts with the Can't open
c:\flexlm\lmgrdl.3EC, errno:3 line.
I have no idea what a 3EC file is about but the lmgrdl is an exe file. The FlexLM
documentation doesn't have an error code for 3. All the error codes (that are published)
are negative values.
Okay. Have you shut down and re-started the server?? It sounds like the service failed to
start and everything is confused. Have you gotten this repeatedly on the server?? If so
check permissions to the folder where the adlm has been installed and check the
permissions for the flexlm service. Make sure that the permissions on the service have
rights to the folder to which flex is installed.
Post back and let us know what happens.
jason martin
frankfurt-short-bruza
"jonhsu" wrote in message news:f0887ee.-1@WebX.maYIadrTaRb...
> I just installed AutoCAD 2002 on a win2k server with 'Client and Autodesk License
Manager Installation' option.
> After configured the license server with the lmtools utility, the following messages
shown in the 'debug.log':
> 8:25:26 (lmgrd) -----------------------------------------------
> 8:25:26 (lmgrd) Please Note:
> 8:25:26 (lmgrd)
> 8:25:26 (lmgrd) This log is intended for debug purposes only.
> 8:25:26 (lmgrd) There are many details in licensing policies
> 8:25:26 (lmgrd) that are not reported in the information logged
> 8:25:26 (lmgrd) here, so if you use this log file for any kind
> 8:25:26 (lmgrd) of usage reporting you will generaJlly produce
> 8:25:26 (lmgrd) incorrect results.
> 8:25:26 (lmgrd)
> 8:25:26 (lmgrd)
> 8:25:26 (lmgrd)
> 8:25:26 (lmgrd) Can't open c:\flexlm\lmgrdl.3EC, errno: 3
> 8:25:26 (lmgrd) Detecting other lmgrd processes...
> 8:25:37 (lmgrd) FLEXlm (v7.1f) started on SVLCA-FS6 (IBM PC) (10/4/2001)
> 8:25:37 (lmgrd) FLEXlm Copyright 1988-2000, Globetrotter Software, Inc.
> 8:25:37 (lmgrd) US Patents 5,390,297 and 5,671,412.
> 8:25:37 (lmgrd) World Wide Web: http://www.globetrotter.com
> 8:25:37 (lmgrd) License file(s): C:\Program Files\Autodesk License
Manager\License\autocad.lic
> 8:25:37 (lmgrd) lmgrd tcp-port 27000
> 8:25:37 (lmgrd) Starting vendor daemons ...
> 8:25:37 (lmgrd) Starting vendor daemon at port 2080
> 8:25:37 (lmgrd) Started adskflex (pid 976)
> 8:25:37 (adskflex) cannot open lock file (C:\flexlm\adskflex): No such file or
directory
> 8:25:52 (lmgrd) MULTIPLE "adskflex" servers running.
> 8:25:52 (lmgrd) Please kill, and run lmreread
> 8:25:52 (lmgrd)
> 8:25:52 (lmgrd) This error probably results from either:
> 8:25:52 (lmgrd) 1. Another copy of lmgrd running
> 8:25:52 (lmgrd) 2. A prior lmgrd was killed with "kill -9"
> 8:25:52 (lmgrd) (which would leave the vendor daemon running)
> 8:25:52 (lmgrd) To correct this, do a "ps -ax | grep adskflex"
> 8:25:52 (lmgrd) (or equivalent "ps" command)
> 8:25:52 (lmgrd) and kill the "adskflex" process
> I didn't have any experience with AutoDesk product, any help will be appreciated!
> Regards,
> Jonathan Hsu
