Installation & Licensing
New Member
Lelana.Mackey
Message 1 of 5 (1,303 Views)
Can't open MatchMover 2012
1303 Views, 4 Replies
12-28-2011 05:54 PM
I'm trying to open MatchMover 2012. An error [-1.359.2] stating A valid license could not be obtained by Network license manager occurs.
I'm not on a network. This is a personal student version.
Second dialogue box indicating Maya error 20.
How can I open MatchMover? See Snap Shot of error messages attached.
Thanks for your help
TravisNave
Message 2 of 5 (1,294 Views)
Re: Can't open MatchMover 2012
12-29-2011 07:01 AM in reply to: Lelana.Mackey
Seems that your error indicates that you installed the product as a network version and you do not have a network license manager installed or setup for this purpose.  Since you are running the student version, you should probably uninstall and reinstall as the stand-alone version with the serial number you were provided.  That should allow for license activation instead of looking for the license manager.
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
New Member
mika.ds
Message 3 of 5 (1,168 Views)
02-21-2012 01:22 PM in reply to: TravisNave
I've been having exactly the same problem with MatchMover using a student version as the person above. Just to be sure, I reinstalled Maya and made sure the license is set to Stand-Alone. However, I still get exactly the same error message as before.
What would be a solution to this problem?
Thanks for help
New Member
d.hutchison
Message 4 of 5 (1,070 Views)
04-10-2012 08:20 AM in reply to: Lelana.Mackey
To solve this problem, you will need to copy the License.env file from the Maya application folder into the Matchmover application folder.
If you are running on a Mac:
  1. Applications > Autodesk > Maya2012 > right click on Maya and select ‘Show package contents’ > Contents > Copy License.env.
  2. Applications > Autodesk > MatchMover2012 > right click on Matchmover2012 and select ‘Show Package Contents’ > Contents > Paste the License.env.
If you are running on Windows:
  1. C:/Program Files/Autodesk/Maya2012/bin > Copy License.env.
  2. C:/Program Files/Autodesk/Matchmover2012 > Paste the License.env.
Thanks to David Lau and Owen:
http://mayastation.typepad.com/maya-station/2011/05/matchmover-2012-standalone-with-maya-2012-standa...
New Member
andrewsgunn
Message 5 of 5 (705 Views)
11-23-2012 06:32 AM in reply to: d.hutchison
Thanks, I've been having exactly the same problem since I got the software. In the end I assumed it was just because it was a student edition that it never worked. I asked my instructor and he said the same thing as me lol.Getting a job as a MatchMover is a great entrypoint for good Visual effects companies such as Double Negative in London.
Once again
Thanks a lot
Andrew :-)
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
