• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Lelana.Mackey
    Can't open MatchMover 2012
    1023 Views, 4 Replies
    12-28-2011 05:54 PM
    I'm trying to open MatchMover 2012. An error [-1.359.2] stating A valid license could not be obtained by Network license manager occurs.
    I'm not on a network. This is a personal student version.
    Second dialogue box indicating Maya error 20.
    How can I open MatchMover? See Snap Shot of error messages attached.
    Thanks for your help
    Please use plain text.
    TravisNave
    Re: Can't open MatchMover 2012
    12-29-2011 07:01 AM in reply to: Lelana.Mackey
    Seems that your error indicates that you installed the product as a network version and you do not have a network license manager installed or setup for this purpose.  Since you are running the student version, you should probably uninstall and reinstall as the stand-alone version with the serial number you were provided.  That should allow for license activation instead of looking for the license manager.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    mika.ds
    02-21-2012 01:22 PM in reply to: TravisNave
    I've been having exactly the same problem with MatchMover using a student version as the person above. Just to be sure, I reinstalled Maya and made sure the license is set to Stand-Alone. However, I still get exactly the same error message as before.
    What would be a solution to this problem?
    Thanks for help
    New Member
    04-10-2012 08:20 AM in reply to: Lelana.Mackey
    To solve this problem, you will need to copy the License.env file from the Maya application folder into the Matchmover application folder.
    If you are running on a Mac:
    1. Applications > Autodesk > Maya2012 > right click on Maya and select ‘Show package contents’ > Contents > Copy License.env.
    2. Applications > Autodesk > MatchMover2012 > right click on Matchmover2012 and select ‘Show Package Contents’ > Contents > Paste the License.env.
    If you are running on Windows:
    1. C:/Program Files/Autodesk/Maya2012/bin > Copy License.env.
    2. C:/Program Files/Autodesk/Matchmover2012 > Paste the License.env.
    Thanks to David Lau and Owen:
    http://mayastation.typepad.com/maya-station/2011/05/matchmover-2012-standalone-with-maya-2012-standa...
    New Member
    11-23-2012 06:32 AM in reply to: d.hutchison
    Thanks, I've been having exactly the same problem since I got the software. In the end I assumed it was just because it was a student edition that it never worked. I asked my instructor and he said the same thing as me lol.Getting a job as a MatchMover is a great entrypoint for good Visual effects companies such as Double Negative in London.
    Once again
    Thanks a lot
    Andrew :-)
