• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    Lelana.Mackey
    Can't open MatchMover 2012
    1049 Views, 4 Replies
    12-28-2011 05:54 PM
    I'm trying to open MatchMover 2012. An error [-1.359.2] stating A valid license could not be obtained by Network license manager occurs.
    I'm not on a network. This is a personal student version.
    Second dialogue box indicating Maya error 20.
    How can I open MatchMover? See Snap Shot of error messages attached.
    Thanks for your help
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Can't open MatchMover 2012
    12-29-2011 07:01 AM in reply to: Lelana.Mackey
    Seems that your error indicates that you installed the product as a network version and you do not have a network license manager installed or setup for this purpose.  Since you are running the student version, you should probably uninstall and reinstall as the stand-alone version with the serial number you were provided.  That should allow for license activation instead of looking for the license manager.
    New Member
    mika.ds
    02-21-2012 01:22 PM in reply to: TravisNave
    I've been having exactly the same problem with MatchMover using a student version as the person above. Just to be sure, I reinstalled Maya and made sure the license is set to Stand-Alone. However, I still get exactly the same error message as before.
    What would be a solution to this problem?
    Thanks for help
    New Member
    04-10-2012 08:20 AM in reply to: Lelana.Mackey
    To solve this problem, you will need to copy the License.env file from the Maya application folder into the Matchmover application folder.
    If you are running on a Mac:
    1. Applications > Autodesk > Maya2012 > right click on Maya and select ‘Show package contents’ > Contents > Copy License.env.
    2. Applications > Autodesk > MatchMover2012 > right click on Matchmover2012 and select ‘Show Package Contents’ > Contents > Paste the License.env.
    If you are running on Windows:
    1. C:/Program Files/Autodesk/Maya2012/bin > Copy License.env.
    2. C:/Program Files/Autodesk/Matchmover2012 > Paste the License.env.
    Thanks to David Lau and Owen:
    http://mayastation.typepad.com/maya-station/2011/05/matchmover-2012-standalone-with-maya-2012-standa...
    New Member
    11-23-2012 06:32 AM in reply to: d.hutchison
    Thanks, I've been having exactly the same problem since I got the software. In the end I assumed it was just because it was a student edition that it never worked. I asked my instructor and he said the same thing as me lol.Getting a job as a MatchMover is a great entrypoint for good Visual effects companies such as Double Negative in London.
    Once again
    Thanks a lot
    Andrew :-)
