Installation & Licensing
Can;t modify Samreport-Lite shortcut to add java version
1 REPLY 1
jweiss1313
1669 Views, 1 Reply
Everytime I try to append the SAmreport-Lite shorcut with the Java version, I get the error that the report.exe cannot be found.  Without this Samreport will not run.  This server is a brand new one running Microsoft Server 2012.  Does anyone have any tips or tricks to getting this to work?
Any help would be appreciated!
John C Weiss Jr.
CAD Manager
Follett LLC.
1 REPLY 1
TravisNave
in reply to: jweiss1313
This is ridiculously more difficult than it should be.
Go out and physically locate the java folder that you have installed, and then copy its address.  Then paste it behind the installation .exe in the command prompt.  That's how I do it.  I was going to do a howto on this but I never got around to it...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
