You will find a Technical Solution with step by step instructions that Frank described here:
http://support.autodesk.com/getdoc.asp?id=TS64756
As you are running license servers from multiple software vendors you will also want to manage the TCP/IP port that the Master Daemon is using for each license service. You will find information and instructions for this in this Technical Solution:
http://support.autodesk.com/getdoc.asp?id=TS67745
Douglas Lauritsen, Autodesk Product Support
We appreciate your quick feedback on this forum!
