Installation & Licensing
Can't login into Infrastructure Map Server mapadmin
1 REPLY 1
816 Views, 1 Reply
I have installed AIMS 2013 on a Windows 7 64 bit OS. I have activated the licence but I can't login into mapadmin with user : Administrator / pass: admin
I have restarted the services, I have even done an uninstall and reinstall of the software.
When I try to connect to mapadmin I get in the LicenseError.log (Autodesk Infrastructure Map Server 2013\Logs\) the following error:
7804    2013/04/02    10:22:15    Reason=Fatal error
7804    2013/04/02    10:22:15    ComputerName=P5RO-PC104
7804    2013/04/02    10:22:15    OS=6.1.7601.Service Pack 1
7804    2013/04/02    10:22:15    File=AdlmIntUTHandler.cpp,Line=166
7804    2013/04/02    10:22:15    VendorID=11 [ADUT]
7804    2013/04/02    10:22:15    VendorError=-104 [Error in accessing PI_UD folder or PI_UD config file]
Also, I have looked the login.php file and when trying to connect to mapadmin the stackTrace message is:
exception 'mgconnectionfailedexception' in D:\AIMS\Autodesk Infrastructure Web Server Extension 2013\www\mapadmin\login.php:82
Stack trace:
#0 D:\AIMS\Autodesk Infrastructure Web Server Extension 2013\www\mapadmin\login.php(82): mgsite->open(Object(mguserinformation))
#1 {main}exception 'mgconnectionfailedexception' in D:\AIMS\Autodesk Infrastructure Web Server Extension 2013\www\mapadmin\login.php:82
Stack trace:
#1 {main}.
Any help would be appreciated,
Thank You,
Iulia Tamas
1 REPLY 1
AnimGI
Hello Lulia, I'm having the same problem with Infrastructure Map Server 2014, Cannot Login to Studio. Did you ever found a fix for this?
I'd like to know. Thank you. DZ
Administrator Productivity
