hi everyone,
The autocad 2012 installation not even begins, appears this message:
The system can not find the path specified. C: Local \ Temp \ AI_461F.tmp \ x64 \ InventorFusion \ InventorFusion.msi
Help me please, my laptop is a hp probook4430s core i5 windows 7 64 bit
Can you try to re-download the software?
Welcome to the community...
Up for this? What do you mean?
The 2013 version is retired and no longer supported.. Do you own an active 2013 serial # for AutoCAD?
Mark Lancaster
& Autodesk Services MarketPlace Provider
I'm confused now... You are asking for AutoCAD 2013 but you installed the trial which would've be 2017.. So which is it?
If you don;t have an active serial # how did you expect to use the product?
Is your friend a student?
Mark Lancaster
If she is a student then she get the software for free (as long as its used for learning/training purposes only) - for 3 years. Has she created a educational account here: http://www.autodesk.com/education/free-software/autocad? From there she will be issued a serial #. If the 2017 is already installed there's no need to install it again. Once she gets that serial # she can activate it.
Mark Lancaster
That link that I provided is there to create her Autodesk Educational account. Once that is completed and she logs in, she will be able see the download for AutoCAD 2017 or any other Autodesk product she requests. But if its already installed on her machine as a trial there's no need to install it again. However if you need to install it, here's what we recommend:
Download and install per:
1. Access the Autodesk Virtual Agent (link is in my signature) and follow the download links to your product.
2. Download all of the parts (some applications only have a single part to download) for your product first. Do not continue until all of the parts have fully downloaded.
3. Navigate to your download folder location and extract (double click) part _001_00X.sfx.exe (or the single file download).
4. In a few seconds the extraction will start and prompt you to extract to C:\Autodesk.
5. Once the extraction is finished, the installation will automatically start.
6. Follow the installation steps for your product
If you want the full recommended installation steps, click on the installation link in my signature.
Good luck on your installation.
Mark Lancaster
