• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    TravisNave
    Re: Can't install autocad 2012 because net framework is missing (but not really)
    10-19-2011 01:34 PM in reply to: lauredefoy1
    They are all simply runtimes and can be safely uninstalled.  They are prerequisites and will be reinstalled when necessary or manually from Microsoft.com.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Please use plain text.
    Contributor cjr
    10-19-2011 02:05 PM in reply to: TravisNave
    I hate to be like this but I have to put this out there...  This computer seems to be acting erratically and it is causing you headaches and many work arounds.  If this was me, I think I would cut my losses and reformat the computer.  Sadly, it will probably take you less time to back up all personal data, reformat, reinstall windows with updates and reinstall programs than it will take to work your way around this.  Besides, even if you do work around this I believe you still are dealing with a messed up and buggy computer.
    I hate to say stuff like that because it sounds like a cop-out but sadly it is probably true and probably the most efficient way to get by this and end up with a good, solid computer.  Just my opinion.
    Chris
    Active Member
    lauredefoy1
    10-20-2011 11:53 AM in reply to: cjr
    I also hate to agree with this but, after all, I must admit I can't act further ! And there's probably no doubt you are right.
    I've tried to pass beside the difficulty but it seems that there is no hope !
    I must admit the smallest allusion to this back up and re-install process give me an headache !  :womansad:
    However, thank you all for your advices and help.
    Member
    Autocad 2010 can't be installed
    03-16-2012 12:17 AM in reply to: lauredefoy1
    I was installing Autocad 2010 to my windows 7 laptop. I have also installed the microsoft.net framework 4 from this site
    http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=17851
    however, when i begin the installation process, a black screen just pops out and then gone. nothing happened. The installation didn't push through... what could be the problem of the installation process?
    PS.
    I have also turned off my antivirus.
    Hope you could help me
    God bless.
    New Member
    03-26-2013 06:36 PM in reply to: cjr
    I have not finished the install but ther gentleman in the prior post that gave the .net 4.0 d/l link was correct after you download and install the preceding .net 4.0 link then you do a Windows Update and there are six more files which have net 4.0 stuff in them and when that finishes I will reply back with another reponse and see if it installs correctly as well...  Sincereley, Alexander The Great
    Alexander E. Calvo
    w0579370@apps.losrios.edu
    New Member
    05-03-2013 05:11 PM in reply to: TravisNave
    Hey guys!
    I'm having the same problem here with cad 2012 architecture... I just tried what Chris said (1st page) and it's not 100% installed but its working, so thanks Chris! You just saved an achitecture student's project!
