• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    Accepted Solution
    Can't install Autodesk Revit 2013 x64 Update1
    1784 Views, 6 Replies
    10-02-2012 07:05 AM
    I've got a problem during the install of Autodesk Revit 2013 x64 Update1 . It causes an installation error. Error Code :1624
    What can i do ? On aother machine de Service Pack installed just fine.
    Regards, Jordi
    Please use plain text.
    Employee
    Re: Can't install Autodesk Revit 2013 x64 Update1
    10-03-2012 11:10 AM in reply to: 5kings
    Hello Jordi
    I've seen other cases where this error occurs when the update fails to find the original install files.  If you installed from a DVD, you may want to pop it into the DVD player and then try running the update again.  If that doesn't resolve the problem, please post the install log file associated with the update (it should be located in the Windows temp directory) and I can see if it holds any clues.
    Tony Michniewicz
    Autodesk Revit QA
    Active Contributor
    10-04-2012 12:44 AM in reply to: tony.michniewicz
    Thanks Tony,
    I'll give it a try.
    Jordi
    New Member
    10-07-2012 09:02 AM in reply to: 5kings
    I am having a similar problem, I have Revit 2013 (student version) and cannot install the update. I have followed the instructions on the Autodesk website and as it is the student version it is downloaded from the student centre. The message I get is as follows:
    "The Update Release could not be installed because the expected Autodesk product could not be located on your computer. Make sure that you are using the correct Update Release fro the product."
    Any help would be appreciated - crashes when doing floors and filled regions is driving me crazy.
    Matt
    New Member
    10-08-2012 02:37 AM in reply to: 5kings
    I managed to figure it out - I forgot I did the OneBox install. Installed the correct update and all sorted.
    Cheers,
    Matt
    New Member
    11-01-2012 08:06 AM in reply to: 5kings
    Yea this was wrecking my head. There are two different download sites –
    Revit standalone:
    Update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121970&linkID=9273944
    Update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679231&linkID=9273944
    as part of the design suite
    update 1: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121968&linkID=16831210
    update 2: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
    Depending on which you have installed one will work – the other you get ‘cannot install as expected Autodesk product cannot be located on your computer’ error message
    Autodesk should make this known on both pages. Would avoid needless confusion and frustration.
    Active Contributor
    11-06-2012 01:14 AM in reply to: tony.michniewicz
    I made a copy of the dvd from the network to my local drive. (for a faster installation) Later on I removed the install files from my local drive. That's the problem.... You've to leave the original install files on it's original place. ( I restored them from the recycle bin......and problem solved)
    Regards, Jordi
