Hi Dashing Boy,
Did you get the download link from Subscription Center? If not, from what particular Autodesk site did you get it?
Note that, although the download for 2015 is visible in your Subscription Center, you will be unable to activate this release until your Contract Manager or Software Coordinator receives the official 2015 Release Notification Email informing them that your product has been upgraded and is now available to you.
Media orders are also not available until the notification email has been received.
If you would like to request media, please have your Contract Manager or Software Coordinator log into the Subscription Center and request a physical shipment after you have received an email notification that your upgrade is available for download.
Lastly, our Development Team has not yet released the official System Requirements for Autodesk 2015 Products.
Hi Alexander,
It looks like the install is failing due to the following: InstallMicrosoft Visual C++ 2005 Redistributable (x64)FailedInstallation aborted, Result=1603
There may be a newer version of the Microsoft Visual C++ 2005 Redistributable Package installed on your computer which is causing the install failure.
A typical workaround is to uinstall Microsoft Visual C++ 2005 Redistributable (x64) via the Control Panel (add / remove programs), reinstall the software, and then install the latest version of Microsoft Visual C++ 2005 Redistributable (x64) from Microsoft (linked here).
For additional 1603 error causes and corresponding solutions, click here, and/or let us know if this works for you!
Hello @turpisw!
Looking at another .exe - Entry Point Not Found forum post yields the following.
Any luck with these suggestions?
OK so when i run the Setup for 3ds max 2015 it runs normally until it gets to what i believe is a materials library it then fails and says that some components have failed and links me to the attached file.
I am running a windows 8
if you need more details i am here!
and maybe i am missing something and this has been solved but i am in a bit of a panic as i have to have 3ds max in working order ASAP
Thanks in advance!
Here to help @koss902!
Can you please try downloading the software directly from the Autodesk Virtual Agent if you haven't already, to circumvent the 1603 error?
Thanks for shooting me the virtual agent but when it opens it asks for the directory where I want to extract the file to, and when I click ok after specifing a directory it says File Corrupted Error and then closes any ideas?
Sure thing! Have you tried disabling any firewalls or antivirus software? What about using a different browser?
hello, i already download the version od 3ds max for windows 64 bits, but its not letting me install is showing that the comunication failure, however my network signal is excellente and i already turn off the firewall.
Hello
I also have a similar problem but it's not a 1603 but a 1619? Should I still uninstall the C++ 2012? I do however have a 1603 for the Medium Resolution Library? And a problem further down with DirectX Runtime which I can't even find on my system 😞
Would appreciate some help 🙂
Vivien
I can't install 3ds Max 2015 Student Version.
I really need help for this. I'm running win 8.1.
Your issue is related to the Autodesk Medium Material Library.
2015/3/27:00:01:48 Lucia LUCIA Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
Please install it from here... http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
May i suggest you download 3DS Max via the Browser Download option rather then Install Now or Download Now.
Hi @clauelr
Your issue again is related to the Autodesk Medium Material Library.
2014/11/26:17:47:34 clauu_000 CLAU Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
