I keep having trouble while I'm installing 3DS Max. I've tried two different versions, the 2010 & 2012 version. In both cases the installation failures. The error log shows the following:
2011/11/21:19:42:43 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:19:42:46 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:19:42:51 Gebruiker GEBRUIK-00PDEP5 === Setup ended ===
2011/11/21:19:50:47 Gebruiker GEBRUIK-00PDEP5 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
2011/11/21:19:51:15 Gebruiker GEBRUIK-00PDEP5 === Setup ended ===
2011/11/21:20:02:36 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:02:38 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:02:43 Gebruiker GEBRUIK-00PDEP5 === Setup ended ===
2011/11/21:20:04:26 Gebruiker GEBRUIK-00PDEP5 === Setup ended ===
2011/11/21:20:06:16 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:06:19 Gebruiker GEBRUIK-00PDEP5 === Setup started on GEBRUIK-00PDEP5 by Gebruiker ===
2011/11/21:20:06:23 Gebruiker GEBRUIK-00PDEP5 === Setup ended ===
2011/11/21:20:09:54 Gebruiker GEBRUIK-00PDEP5 Install Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1603
How can I resolve this problem?
Hi Robinu92.
Can you please try the solution on this thread and let us know if it works for you?
Thanks!
Well I can't find both register keys and the cofigurationmanager does not show any Visual C++ installed, so I don't get it? By the way my PC runs on Windows 7.
Hi robinu92.
Sorry to hear the first solution did not work.
I will suggest you look at this thread, spcifically post number 7 is a good starting point to resolve your issue.
If this works, please hit "Accept as Solution" to help other users find the answer to this question!
Thank you.
Well the problem still in't resolved. First I don't know how to uninstall the vcredist files? I've tried to install the vcredist files but then I get a new error. The error says that I need to locate the source which contains the vredist.msi file. So where can I find this file?
hi, Try to unistall Mocrosoft c++ 2005 from controlpanel and reinstall
