I downloaded AutoCAD_2011_EFSB_Win_64bit.exe from my subscription page. I need to create a network deployment, but when I run this file, it displays a simple dialog box that has just an "Install" and "Cancel" buttons -- no setup wizard. If I click Install, it starts installing to my C: drive, along with a list of files whizzing by as they are extracted.
Did I download the wrong file? It was the only AutoCAD file listed for me to download, and the Civil 3D and Raster files I downloaded from the same page run the setup wizard just fine. Or do I need to do something different to get to the setup wizard?
Solved by hashim.mundol. Go to Solution.
I assume you are seeing the file extraction process.
Install files are extracted to C:\Autodesk\Productname, installation setup should start after this extraction process
if it doesn't you can manually start the setup.exe from the above folder.
Setup wizard....!!
at 1st place i should say that has been very very hard to me the logging in process. my username was right, also my password
but maybe the fact that im using internet explorer and that i chosed to remain conected, or maybe some other reason, was for me impossible to log in or change the password. i was unable to log in, while the changing password process was all the time telling that the kind of password that i was typing as new was wrong kind, until ive seen that i was logged in yet.. ! crazy.
but doesnt matter. im finally here! but i prefer to not move or i could result as signed out, and i need help. is not the exact them exposed in this post, but is the same kind, as soon as is about the wizard for new drawings, and this discussion gropu is about a setup wizard in autocad 2011.
so thats the question: Where is the setup wizard in Autocad 2011 for new drawings? ive got the spanish version, and is not anywhere! ive checked a book (about autocad 2006), ive checked the web, where it says that in 2010-11 should be there the wizard when you start a new drawing. but is not there!? where it is? i think that ive checked nearly all the program! well, instead all my particular troubles to be here, ive come because i think that is the only place where i can ask about. there are no chats, or mails or other kind of systems to talk to other users or developers. this one is the only one that i know, so im here: where is the startup wizard for new drawings? in spanish would be "asistente para nuevo dibujo" or something like that.
thanks a lot!
