Installation & Licensing
Can't find AutoCAD 2012 please help
6 REPLIES 6
M240
981 Views, 6 Replies
I want to put my AutoCAD2012 program on another PC. I have looked at your home page, but I can´t find AutoCAD 2012. Where can I download AutoCAD  2012?. Will someone help me please?
6 REPLIES 6
bryce.thelin
in reply to: M240
Once a new version of AutoCAD is released, the old one is not available to download anymore. However, if you have Subscription support with us, you can download older versions through your Subscription Center account:
http://subscription.autodesk.com
If you have downloaded and installed AutoCAD on a computer previously, the installation files are extracted to C:\Autodesk. You can copy these over to the system that you want to install onto.
The last option for you would be to call the Autodesk Business Center at (800) 538-6401. They can setup an FTP download for you.
Bryce Thelin
AutoCAD Product Support
TravisNave
in reply to: M240
For student versions, start here:
http://students.autodesk.com/?nd=download_center
For the commercial trial version that you can activate with your serial number, start here:
http://usa.autodesk.com/autocad/trial/
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
M240
in reply to: M240
No im not a student just need to get the setup .exe file for 2012 so i can install it on my work laptop
TravisNave
in reply to: M240
You can download and activate the trial or get it from your Subscription center login using any of the links above.
Autodesk Forums:
philip.s
in reply to: M240
M240,
I've attached the following 72hr timed direct download links for your convenience.
AutoCAD 2012 32BIT - LINK
AutoCAD 2012 64BIT - LINK
M240
in reply to: M240
Thanks guys you have been very helpful
Administrator Productivity
