I want to put my AutoCAD2012 program on another PC. I have looked at your home page, but I can´t find AutoCAD 2012. Where can I download AutoCAD 2012?. Will someone help me please?
Solved by philip.s. Go to Solution.
Once a new version of AutoCAD is released, the old one is not available to download anymore. However, if you have Subscription support with us, you can download older versions through your Subscription Center account:
http://subscription.autodesk.com
If you have downloaded and installed AutoCAD on a computer previously, the installation files are extracted to C:\Autodesk. You can copy these over to the system that you want to install onto.
The last option for you would be to call the Autodesk Business Center at (800) 538-6401. They can setup an FTP download for you.
For student versions, start here:
http://students.autodesk.com/?nd=download_center
For the commercial trial version that you can activate with your serial number, start here:
http://usa.autodesk.com/autocad/trial/
You can download and activate the trial or get it from your Subscription center login using any of the links above.
M240,
I've attached the following 72hr timed direct download links for your convenience.
