Installation & Licensing
New Member
usfjerry
Message 81 of 145 (728 Views)
Re: Can't download any Autodesk product from student community
02-16-2013 02:45 AM in reply to: WillSeath
I was issued a serial number and the "browser download" button appears for me. However, when I click on the button, nothing happens. That is my only option. I was attempting to downlaod 3DS Max 2012.
Customer Service
joane.bonghanoy
Message 82 of 145 (704 Views)
02-18-2013 12:20 AM in reply to: usfjerry
Hi Gerald,
Install Now option is available if you are downloading 2013 version. I generated AutoCAD 2013 using your profile and all other Download Options/buttons can be seen.
For 2012 download, I suggest you you use other browsers other than the one you are currently using.
Joane Bonghanoy
New Member
coronaboy15
Message 83 of 145 (669 Views)
02-24-2013 06:07 PM in reply to: WillSeath
Hi, I was trying to download Windows 32-bit Autodesk 3DS Max by Install Now and Download Now. To put it shortly, they didn't work and now I'm trying Browser Download. From what I see on this forum, this has been a common problem.
Is there anything I'm doing wrong, and what can I do to get it on my computer if Browser Download doesn't work?
arlinpega.bibat
Message 84 of 145 (659 Views)
02-24-2013 07:31 PM in reply to: usfjerry
Hi usfjerry:
You can download Autodesk 3DS Max 2012 through this link. Please note that the link is valid only for 5 days. If you encounter any activation issue, you can contact our Registration and Activation team directly.
Best Regards,
Arlin Bibat
Active Member
dukduks
Message 85 of 145 (530 Views)
04-30-2013 03:29 AM in reply to: arlinpega.bibat
i am having problems trying to download autodesk 3ds max design 2013 from the student community, nothing happens when i click on the either the install now or browser donload prompt, please note that i am running on windows 8. kindly assist.
camilo.lemos
Message 86 of 145 (527 Views)
04-30-2013 03:53 AM in reply to: dukduks
Hi dukduks,
I've tested both the Install Now and Browser Download methods to download 3ds Max Design 2013 from the Education Community and I was able to get the program without a problem.
Here are two direct download links, valid for 72 hours. I would suggest you check your firewall and anti-virus settings before trying to download and see if they are not blocking content from *.autodesk.com:
3ds Max Design 2013 32-bit
3ds Max Design 2013 64-bit
Let me know if these work for you, please.
Camilo Lemos
Active Member
dukduks
Message 87 of 145 (520 Views)
04-30-2013 07:43 AM in reply to: camilo.lemos
thank you ever so much, the direct link worked right away, i am eternally greatfull to you.
Active Member
dukduks
Message 88 of 145 (490 Views)
05-04-2013 07:30 AM in reply to: dukduks
hello,
I am having problems licensing the product yet i have a student license, a pop-out window 'autodesk licensing' appears and hangs while trying to run the program, if i cancel it i am told that i am running a trial version and it expires in a month's time. Kindly assist to license the product.
philip.s
Message 89 of 145 (478 Views)
05-05-2013 03:17 PM in reply to: dukduks
Hello Shadrack,
Can you please provide a screen shot of the hanging licensing screen?
Philip Schmelzer
Active Member
dukduks
Message 90 of 145 (463 Views)
05-06-2013 06:30 AM in reply to: philip.s
the activation page shows a blank with only two radio buttons, please note that i have tried everything on http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617 but it doesn't seem to work. i am running on windows 8 that came with a pre-installed  ie10. is there a manual way to activate my product??
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
