Installation & Licensing
New Member
ebottens
Message 71 of 145 (1,123 Views)
I am having the same issues
01-15-2013 09:06 PM in reply to: WillSeath
Trying to install AutoCAD 2013 and no luck tells me that there is an error, I get it to download I think, but when it goes to install it freezes up and then I get the error that Windows Explorer needs to close and a screen comes up and says that all the programs have failed to install, Im falling behind in class!! PLEASE HELP!!  Tried clearing cache, etc.....other browsers, browser download, download now, eetc....
New Member
irina-ov
Message 72 of 145 (1,121 Views)
Re: Can't download any Autodesk product from student community
01-15-2013 10:10 PM in reply to: WillSeath
I also cannot download student Autodesk 3 ds Max 2013. Error file is:
2013/1/15:22:30:44    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/15:22:30:44    admin    ADMIN-PC    Launch
2013/1/15:22:30:55    admin    ADMIN-PC    === Setup ended ===
2013/1/15:22:30:47    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/15:22:30:47    admin    ADMIN-PC    Launch
2013/1/15:22:30:55    admin    ADMIN-PC    PageOpen    LaunchDialog
2013/1/15:22:31:00    admin    ADMIN-PC    PageOpen    LicenseDialog
2013/1/15:22:31:11    admin    ADMIN-PC    PageOpen    ProductInfoDialog
2013/1/15:22:32:50    admin    ADMIN-PC    PageOpen    ProductSelectionDialog2
2013/1/15:22:32:56    admin    ADMIN-PC    PageOpen    FullProgressDialog
2013/1/15:22:32:57    admin    ADMIN-PC    Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\admin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/1/15:22:33:27    admin    ADMIN-PC    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1603
2013/1/15:22:33:30    admin    ADMIN-PC    PageOpen    InstallCompleteDialog
2013/1/15:22:33:41    admin    ADMIN-PC    === Setup ended ===
2013/1/15:23:59:22    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/15:23:59:22    admin    ADMIN-PC    Launch
2013/1/15:23:59:36    admin    ADMIN-PC    === Setup ended ===
2013/1/15:23:59:28    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/15:23:59:28    admin    ADMIN-PC    Launch
2013/1/15:23:59:37    admin    ADMIN-PC    PageOpen    LaunchDialog
2013/1/16:00:03:02    admin    ADMIN-PC    PageOpen    BeginDeploymentDialog
2013/1/16:00:03:14    admin    ADMIN-PC    PageOpen    LaunchDialog
2013/1/16:00:03:28    admin    ADMIN-PC    PageOpen    LicenseDialog
2013/1/16:00:03:28    admin    ADMIN-PC    PageOpen    ProductSelectionDialog2
2013/1/16:00:03:41    admin    ADMIN-PC    PageOpen    FullProgressDialog
2013/1/16:00:03:41    admin    ADMIN-PC    Installing Autodesk® 3ds Max 2013 SDK:  TRANSFORMS="C:\Users\admin\AppData\Local\Temp\_AIF623.tmp\x86\Tools\MAXSDK\SDK_3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" INSTALLDIR="C:\Program Files (x86)\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:00:04:33    admin    ADMIN-PC    Install    Autodesk® 3ds Max 2013 SDK    Succeeded
2013/1/16:00:04:33    admin    ADMIN-PC    Installing Network License Manager:  ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\"  ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2013/1/16:00:04:50    admin    ADMIN-PC    Install    Network License Manager    Succeeded
2013/1/16:00:04:50    admin    ADMIN-PC    PageOpen    InstallCompleteDialog
2013/1/16:00:05:02    admin    ADMIN-PC    === Setup ended ===
2013/1/16:00:22:41    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/16:00:22:41    admin    ADMIN-PC    Launch
2013/1/16:00:22:54    admin    ADMIN-PC    === Setup ended ===
2013/1/16:00:22:47    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/16:00:22:47    admin    ADMIN-PC    Launch
2013/1/16:00:22:54    admin    ADMIN-PC    PageOpen    LaunchDialog
2013/1/16:00:22:59    admin    ADMIN-PC    PageOpen    LicenseDialog
2013/1/16:00:23:07    admin    ADMIN-PC    PageOpen    ProductInfoDialog
2013/1/16:00:24:52    admin    ADMIN-PC    PageOpen    ProductSelectionDialog2
2013/1/16:00:25:16    admin    ADMIN-PC    PageOpen    FullProgressDialog
2013/1/16:00:25:17    admin    ADMIN-PC    Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\admin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/1/16:00:25:28    admin    ADMIN-PC    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1603
2013/1/16:00:25:33    admin    ADMIN-PC    PageOpen    InstallCompleteDialog
2013/1/16:00:27:33    admin    ADMIN-PC    === Setup ended ===
2013/1/16:00:54:19    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/16:00:54:19    admin    ADMIN-PC    Launch
2013/1/16:00:54:41    admin    ADMIN-PC    === Setup ended ===
2013/1/16:00:54:28    admin    ADMIN-PC    === Setup started on ADMIN-PC by admin ===
2013/1/16:00:54:28    admin    ADMIN-PC    Launch
2013/1/16:00:54:41    admin    ADMIN-PC    PageOpen    LaunchDialog
2013/1/16:00:54:52    admin    ADMIN-PC    PageOpen    LicenseDialog
2013/1/16:00:54:57    admin    ADMIN-PC    PageOpen    ProductInfoDialog
2013/1/16:00:57:59    admin    ADMIN-PC    PageOpen    ProductSelectionDialog2
2013/1/16:00:58:26    admin    ADMIN-PC    PageOpen    FullProgressDialog
2013/1/16:00:58:27    admin    ADMIN-PC    Installing Microsoft Visual C++ 2005 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\admin\AppData\Local\Temp\vcredist_x64_2005.log"" "
2013/1/16:00:58:53    admin    ADMIN-PC    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1603
I tried a few times, same results.
camilo.lemos
Message 73 of 145 (1,114 Views)
01-16-2013 12:19 AM in reply to: irina-ov
Hi ebottens and irina-ov,
My initial suggestion to anyone having issues downloading or installing software from the Education Community is to check that your computer meets all the minimum system requirements for that product. Trying different browsers and download methods, as ebottens has already done, is also a good option.
For those getting an error code 1603, saying that some or all programs failed to install, our Expert Elite member TravisNave put together a great post teaching how to fix the error. You can find that post here.
Can you please follow the instructions mentioned on TravisNave's post linked above and let us know if the problem persists?
Thank you!
Camilo Lemos
New Member
gapouliasis
Message 74 of 145 (1,084 Views)
01-22-2013 05:03 AM in reply to: philip.s
I have tried again this time downloading a trial version and worked fine. There wasnt a complete error message just the error code but now it seems that is working just fine.
New Member
jr.lancers
Message 75 of 145 (1,071 Views)
01-22-2013 06:13 PM in reply to: WillSeath
   I have tried downloading 2012 AutoCad several times. I even tried 2013 version so I could use the DLM from AutoDesk to no avail. I get it "downloaded" to computer then it wants to download again, put in my codes & everthing seems fine. Upon " initialization " it gets several parts loaded/initialized  & almost gets done loading/initializing                 " autocad"  & then " error code 2738" pops up & starts backing out the download for both versions. I am running Vista /AMD Sempron Proc LE-1250/2.2GHz/2GB RAM.
Customer Service
joane.bonghanoy
Message 76 of 145 (1,065 Views)
01-22-2013 06:48 PM in reply to: jr.lancers
Hi jr.lancers,
Is the error the same as on this link? If so, follow the troubleshooting steps and solution provided.
Joane Bonghanoy
New Member
chdavis
Message 77 of 145 (1,005 Views)
02-02-2013 06:12 AM in reply to: philip.s
Hi Philip,
I am trying to download the most recent version of Civil 3d (64-bit) and Revit 2013 (64-bit) and cannot view the "download" radio button on the Autodesk Student Community website.  Is there anyway that you could send me links to download programs mentioned above?  Also, I'm operating on a Windows 7 OS.  Thank you for your time and help!
New Member
ryanm567
Message 78 of 145 (1,001 Views)
02-02-2013 06:59 AM in reply to: WillSeath
I can't download inventor or inventor publisher from the student download page, there is no download button.
New Member
d.pwright
Message 79 of 145 (988 Views)
02-02-2013 08:22 AM in reply to: camilo.lemos
this same error has occurred for me to download the Standard AutoCAD 2013 64-bit O.S, as there is not a download button to do so. Please can you help me to resolve this situation.
philip.s
Message 80 of 145 (932 Views)
02-02-2013 05:28 PM in reply to: d.pwright
My apologies for the inconvenience everyone.
Confirming that the missing download buttons have been restored and you can now again enjoy your full Education Community benefits.
Thank you very much for your patience and please let us know if any additional questions, concerns or issues arise.
Philip Schmelzer
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
