I have a few users that use our network license. Everything has been working fine, but for some reason, the license manager is not working now. From LMTools, Start/STop/Reread tab, ReRead License File > I get "ReRead Server Failed". On the "Perform Status Enquiry" Command, I get:
Status -------- Flexible License Manager status on Thu 4/18/2013 08:07
[Detecting lmgrd processes...] Error getting status: Cannot connect to license server system. The license server manager (lmgrd) has not been started yet, the wrong port@host or license file is being used, or the port or hostname in the license file has been changed. Server name: 192.168.0.79 License path: @192.168.0.79; FLEXnet Licensing error:-15,570
I think the problem is the 192.168.0.79 address. This is NOT the address for the Host.... it is 192.168.0.62
How do I get it to look at the correct path?
Solved by DarrenP. Go to Solution.
try this: http://forums.autodesk.com/t5/Installation-Licensing/Could-not-obtain-license/m-p/3873499#M61292
DarrenP
