I can't install, put the CD on the PC, run it give me the initial screen, press install and all I get.............
1st Error 1327 Invalid Drive E:\ Press OK
2nd Fatal Error during Installation # 360 (this # changes with every try), Fail to run AutoDesk Executable Sequence
Press OK
3rd Failed to Initalize AutoCAD Lite 2012 Press OK
and that is as far as I got =(
I'm lost don't know what to do? who to call ???
Any help will be apreciated
Sam Escobedo
sounds like bad media
try copying the cd to the hard drive and install from there
DarrenP
I found a solution in Knowledge Base:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2899085&linkID=9240817
Can it help you?
regards
Giovanni
