Installation & Licensing
Can't Install the New AutoCAD LT 2012
3 REPLIES 3
338 Views, 3 Replies
I can't install, put the CD on the PC, run it give me the initial screen, press install and all I get.............
1st     Error 1327 Invalid Drive E:\    Press OK
2nd    Fatal Error during Installation # 360 (this # changes with every try), Fail to run AutoDesk Executable Sequence
Press OK
3rd     Failed to Initalize AutoCAD Lite 2012   Press OK
and that is as far as I got  =(
I'm lost don't know what to do? who to call ???
Any help will be apreciated
Sam Escobedo
3 REPLIES 3
DarrenP
sounds like bad media
try copying the cd to the hard drive and install from there
DarrenP
The main issue is that the CD is in drive D:\ why does it want to go to an inexisting Drive?
gperego
I found a solution in Knowledge Base:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2899085&linkID=9240817
Can it help you?
regards
Giovanni
Administrator Productivity
