• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    New Member
    Accepted Solution
    Can't Install on a non-bootable Hard drive
    1553 Views, 6 Replies
    04-11-2012 07:03 AM
    I just recieved my copy of Revit Structure 2013. I am running a SSD with very limited space left (about 3gb). I also have another hard drive for programs. I want to install Revit 2013 onto the other Hard drive. So during install I change the "Installation Path" from C:\Programs\Autodesk (SSD) to B:\Programs\Autodesk (the other Hard drive). But even doing this it still wants to install 9.23gb on the SSD and only 873mb on the other hard drive. Whats going on here? Any suggestions?
    Thanks!!!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: Can't Install on a non-bootable Hard drive
    04-11-2012 08:25 AM in reply to: chris
    There are always going to be files that will need to be installed to your root.  These are files linking to your profile, system dlls, prerequisite installs, material libraries, SQL server, etc.
    You should really make sure that you always have no less than 20% free space on your C:\. Consider moving your swap file and other files to your extra drives.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    Employee
    04-11-2012 10:02 AM in reply to: chris
    By default all the Templates and Libraries for Revit are still trying to install to C:\ProgramData.
    On the product selection dialog of the install, just under the Revit Structure 2013 name pick the arrow to configure the install.
    Scroll down to the Configurable Folders section
    Change the Libraries and Templates from Default to Local
    Specify a path on the B driver where you want these files and choose the Append button
    When done choose the arrow again to complete the configuration
    Should use much less space on the C drive now although some space will still be required.
    Danny Hubbard
    QA Analyst
    Autodesk, Inc.
    New Member
    04-11-2012 10:35 AM in reply to: DannyHubbard
    Thanks Danny. That worked. Installed and running!
    New Member
    06-14-2012 11:01 AM in reply to: DannyHubbard
    Im have the exact same problem except with the Building design suite, however I cannot even make it to the product select screen in the installer, i'm met with this message when I go to install
    The system cannot find the path specified.
    C:\Users\Name\AppData\Local\Temp\_AI2DD4.tmp\Content\ADSKMaterials\2013\ILM\MediumImageLibrary2013.msi
    Any help would be greatly appreiciated.
    *Expert Elite*
    TravisNave
    06-15-2012 08:50 AM in reply to: danielgriffiths8797
    Install as another user with local admin rights, UAC turned off, and anti-virus disabled.
    Travis Nave
    New Member
    02-15-2013 05:06 AM in reply to: DannyHubbard
    There is no configurable folders section if trying to use mudbox.
