Hello. Don’t see your attachment. The issue is likely 8.1 related.
http://upandready.typepad.com/up_and_ready/2013/10/windows-81-support-please-upgrade-cautiously.html
Can you upload the image?
Thank you for taking part in our community!
zee87 ,
Hello. That particular error usually means your are trying to install with your Antivirus turned on. Turn off yoru Antivirus completely and then try to reinstall. Sometimes you need to kill a service in the task manager to get AV to completely shut off.
Currently, you are being blocked from accessing your temp space with the installer.
You also appear to be using an E:\ drive in this process. Are your files stored on E:? I would also move them to C:\ and see if you can install from there.
I experienced similar problems. Recently I've moved from Windows 7 to Windows 8.1 and I could not install the 3DS Max 2014. The installation would go to step "Left 8 out of 14" and then give an error. When I looked at the log, the error was a bit confusing as it could mean that one of the libraries could not be loaded or that C++ 5.0 could not be installed. I tried several possible options and looked at numerous forums. Finally I've done the following combination of actions which allowed the installation to succeed, however, I am not sure which one of them did the magic, some of my points may only be my crazy ideas but they worked. Here it goes:
Good luck!
