Installation & Licensing
Anonymous(anon)
Message 1 of 7 (172 Views)
Can't Get a Report Log
172 Views, 6 Replies
09-12-2002 07:12 AM
I've followed the documentation, articles in the knowledge base, and advice here in the discussion groups; and still can't get flexlm to generate a report log. What am I doing wrong?
I am using flexlm version 7 on a Windows 2000 server. My adskflex.opt file is in the same folder as my license file and reads as follows:
REPORTLOG +e:\apps\autodesk\license\log\autodesk.rl
The vendor/daemon line in my license file looks as follows:
VENDOR adskflex port=2080
I have restarted the flexlm service using the lmtools.
E:\ is a local drive on the server.
According to the documentation, I should not have to specify an "options=..." in my license file since I am on version 7, though I did try it and it didn't work either.
Can someone help me?
*milana, jerry
Message 2 of 7 (172 Views)
Re: Can't Get a Report Log
09-12-2002 07:28 AM in reply to: Anonymous
The first thing to do is look in your debug log
file and see if the options file is being read.  You should see a line like
9:35:54 (adskflex) Using options file: "
face="Times New Roman"
size=3>e:\apps\autodesk\license
\adskflex.opt"
If you don't see the above, look for a typo in the
options file filename.  If the filename is good, double check your
afskflex service definition for the path to your license file.
Be aware that the options file syntax is case
sensitive.  Make sure that the keyword REPORTLOG in upper
case.
Jerry Milana
Autodesk Professional Services
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I've
E:\ is a local
*Ahava, Petri
Message 3 of 7 (172 Views)
09-13-2002 08:17 PM in reply to: Anonymous
Hi!
I have no idea why you aren't getting a file!!!??? See my notation in the
opt-file!
The only thing I see different is the cappslock thing.... and name of
file... Try changing the name... shouln't matter though...
Petri
Also check how your directorynames are (capslock - no capslock.....)
"sregister" wrote in message
news:f10df83.-1@WebX.maYIadrTaRb...
REPORTLOG +e:\installs\Flex\License\REPORT.RL
Anonymous(anon)
Message 4 of 7 (172 Views)
Re:
09-17-2002 07:33 AM in reply to: Anonymous
It is not creating a debug log. I checked the path for the debug log and there is nothing wrong with it.
I can't seem to find anything wrong. Everything seems to be correct.
I just restarted my server and now I am not getting any licenses. I think I may reinstall the flexlm.
*milana, jerry
Message 5 of 7 (172 Views)
Re:
09-17-2002 09:03 AM in reply to: Anonymous
What makes you think that the license manager is
running at all?  If you are not creating so much as a log file then I doubt
it is running.  Did you check Task Manager?  In any case, I doubt
reinstalling will help.  Instead, try deleting the service you setup for
the adskflex daemon and recreate it.
Jerry
It
Anonymous(anon)
Message 6 of 7 (172 Views)
Re:
09-17-2002 09:04 AM in reply to: Anonymous
I think my systems manager has some explaining to do. The permissions on the local E:\ drive changed somehow so flexlm couldn't access it. I put everything on the local C:\ drive and it all works fine.
*milana, jerry
Message 7 of 7 (172 Views)
Re:
09-17-2002 09:52 AM in reply to: Anonymous
Glad you got it running and thanks for letting us
know!
jerry
I
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
