my OS is Winxp 32 bits.
There is no Autodesk simulation CFD from the Control Panel\Add or Remove Programs.
But it does exist in my desktop. the short-cut is there, the installaiton foler is not empty.and even I can double click the cfd short-cut in the desktop and run simulation CFD normally!
I tried to use the setup.exe to repair the installation. but no that repair option exist. and the new installation option is ready there, but the installaiton cannot complete normally.
Can anyone help me?
Thanks in advance.
Solved by TravisNave. Go to Solution.
For all installation problems on Windows XP, consider using the Microsoft Installer Clean Up Utility. For more information on this program, please my forum post here:
http://forums.autodesk.com/t5/Installation-Licensing/Microsoft-Installer-Clean-Up-Utility-for-Add-Re...
