Installation & Licensing
Can I un-install autocad2006 and install it on another PC?
1 REPLY 1
lamely
213 Views, 1 Reply
what is the procedure needed to move autocad2006 from one PC to another?
(un-install from PC1 and install on PC2)
Do I need to call autodesk? Or simply activate it using the request code on PC2?
FYI: I've already un-installed autocad2006 on PC1.
yes, it's a single license copy of autocad.
1 REPLY 1
TravisNave
in reply to: lamely
If you've already uninstalled it, then go ahead and reinstall in on a new PC. You should be able to activate it without an issue. If it is already locked-out, then you will need to contact Autodesk and get it done.
Next time, use the PLU to extract your license for your new PC and then import it.
Autodesk Forums:
Administrator Productivity
