When I install "Educational Suite for Entertainment Creation 2011", 2 fles and 2 folders are created on D drive.
+ adlmint.dll
+ adlm_libFNP.dll
+ en-US
+ ja-JP
Install folder is C:\Program Files\Autodesk.
I choose "Maya", "Mudbox", and, "MotionBuilder".
Can I delete those files?
Sincerely yours,
nao70
Solved by hashim.mundol. Go to Solution.
They are required for licensing.
Thanks.
But I don't understand why those files are exist on D:/...
Those files and folders are exist not only D-drive but also C-drive.
ex.
C:\Program Files\Autodesk\Maya2011\bin\adlmint.dll
C:\Program Files\Autodesk\Maya2011\MatchMover\adlmint.dll
C:\Program Files\Autodesk\Autodesk MotionBuilder 2011 64-bit\bin\x64\adlmint.dll
C:\Program Files\Autodesk\Mudbox2011\adlmint.dll
D:\adlmint.dll
nao70
you can delete it from 😧
is 😧 marked as Temp folder ? not sure why you have a copy there.
Hey there not to hijack the thread but i'm having exactly the same problem...
I have student versions of max, maya and motionbuilder all installed on C:
😧 is set up for project folders and then my F: drive is personal storage.
When i run any of these programs the above mentioned files are created and then if i delete these files they are created again the next time i run the software. Its not critical that they be removed from my F: drive but i'd simply rather they weren't there if for nothing more than neatness's sake!
i'd really appreciate any light that can be shed on this matter.
thanks in advance. p.
