I cannot activate my cad, I'm ready get my stand-alone license but cannot lay number on it?? Don't know way??
I try to uninstall and reinstall again and again....but still got the same problem!!
My operation system is Win7 Home Premium 64-bit, Intel i7 CPU Q 740 @ 1.73GHz, ram 8G
I try use the same this cad cd package to install another PC, it's worked....Only my PC that cannot T^T
Solved by TravisNave. Go to Solution.
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
You're quite welcomed. That is what we're here for. Glad you are up and running.
Help Improve the Autodesk Discussion Groups
If I was able to resolve your issue, please select the "Accept as Solution" option so that you can help fellow members quickly find solutions to their problems. Please add Kudos to a post if you were helped by a post that you did not author.
