• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Member
    CFD 2013 -how you configure to look for the license server
    220 Views, 1 Replies
    07-04-2012 11:50 PM
    My problem is the CFD 2013 can not find the license server. After installation, It automatically generated this LICPATH.LIC where it puts the (xxxx) server name I keyed in. I wonder if you still need to configure something on the .LIC in order to find the server. I have configured the license using LMTOOLS as per  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=18318727&linkID=9240617#section5 . But it prompts me an error when the license is launched.
    Looks like the way CFD2013 looking for the server name is totally different approach compared to the CFD2011. I tried running our CFD2011 and it can run using the same server name.Anyone can share some experience and info how I can fix this problem.
    Please use plain text.
    TravisNave
    Re: CFD 2013 -how you configure to look for the license server
    07-05-2012 02:14 PM in reply to: XPMechEngr
    You cannot configure the NLM with the LICPATH.LIC file.  This is not a valid license file. It is simply a pointer file that directs the client to the NLM server for a license.  You need to obtain the license from Autodesk or your Reseller and configure it properly.
    For a Quick-Start Guide on configuring the Autodesk License Manager, please see my post for further information:
    http://forums.autodesk.com/t5/Installation-Licensing/Quick-Start-Guide-for-Configuring-LMTOOLS/m-p/3...
    Please call Autodesk Product Registration and Authorization:
    http://en.autodesk.ca/adsk/servlet/index?siteID=9719649&id=9830778
    1-800-551-1490 > Option 1 (English) > Option 2 > (Network)
    Asia / Pacific: 65.6735.5688
    Europe / Middle East / Asia: 41.32.723.9595
    You will need to provide your serial number and ethernet ID of the new license server.
    Good Luck!
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
