Installation & Licensing
Member
kristinwinters1
Message 1 of 3 (119 Views)
CER_81270302
119 Views, 2 Replies
06-17-2013 10:52 AM
I have tried installing Autodesk Building Design Suite Premium 2014  everyway possible (download, install, browser install, and even orderded the USB drive from Autodesk) and none work.  I start set up and while it still says "initializing" an error window pops up and says Autodesk has encountered a problem and needs to shut down.  Then the error report brings up the following code: CER_81270302. I cannot figure out what the problem is or how to fix it.  Can anyone help????
TravisNave
Message 2 of 3 (113 Views)
Re: CER_81270302
06-17-2013 11:08 AM in reply to: kristinwinters1
Welcome to the boards Kristin! :smileyhappy:
When it comes to installing the software, I generally recommend the following:
1.  Your user account has local admin rights to the machine, or you login with Administrator.
2.  You Disable UAC.  (requires reboot)
3.  You Disable Anti-Virus
You might even create a new user on your machine as an administrator and install as that user.
If it still fails, you might have some sort of malware infection and/or your Windows files need updated with Windows Update.
Don't give up!
Travis Nave Send TravisNave a Private Message                       Need help in your post? Mention me with @TravisNave
Product Support
asburyj
Message 3 of 3 (82 Views)
Re: CER_81270302
06-20-2013 04:19 PM in reply to: TravisNave
To follow up on this case the root cause was the presence of the "Displaylink Core Software". Removing it from the system resolved the issue.
More info on this at the below link
http://upandready.typepad.com/up_and_ready/2012/05/general-installation-dlumd32dll-displaylink-core-...
Jeffry Asbury
You are not logged in.
Ask the Community
Up & Ready Blog
Boldly Install, Configure and Deploy Autodesk Software.
AutodeskHelp Blog
Your one-stop shop for the latest solutions, breaking news, and behind the scenes access to the world of Autodesk support.
Connect with Us
Twitter
Pinterest
Blog
Youtube
