• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    CANNOT install completely
    217 Views, 1 Replies
    04-22-2012 08:19 PM
    Hi, In Revit 2011 installation package,I am ONLY able to install Autodesk design review 2011...None of Revit 2011 or revit viewer can be installed... Is there anyone can help me with it? thanks a lot! THE INSTALLATION REPORT IS SHOWN BELOW, but i cannot understand....
    2012/3/12:04:57:54 HP HP-HP === Setup started on HP-HP by HP ===
    2012/3/12:04:57:54 HP HP-HP Launch
    2012/3/12:05:01:20 HP HP-HP PageOpen LaunchDialog
    2012/3/12:05:02:48 HP HP-HP PageOpen LicenseDialog
    2012/3/12:05:03:32 HP HP-HP PageOpen ProductInfoDialog
    2012/3/12:05:04:15 HP HP-HP PageOpen ProductSelectionDialog2
    2012/3/12:05:04:48 HP HP-HP PageOpen FullProgressDialog
    2012/3/12:05:04:48 HP HP-HP Installing Microsoft Visual C++ 2005 Redistributable (x86): C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x86\VCRedist\2005\vcredist_x86.exe /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\HP\AppData\Local\Temp\vcredist_x86_2005.log"" "
    2012/3/12:05:05:23 HP HP-HP Install Microsoft Visual C++ 2005 Redistributable (x86) Succeeded
    2012/3/12:05:05:23 HP HP-HP Installing .NET Framework Runtime 3.5 SP1 Language Pack: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\ /q /norestart /c:"install.exe /qn"
    2012/3/12:05:05:23 HP HP-HP Install .NET Framework Runtime 3.5 SP1 Language Pack Failed Failure is ignored, Result=5
    2012/3/12:05:05:23 HP HP-HP Installing DirectX® Runtime: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\DirectX\DXSETUP.exe /silent
    2012/3/12:05:08:34 HP HP-HP Install DirectX® Runtime Succeeded
    2012/3/12:05:08:35 HP HP-HP Installing Microsoft VSTA Dependencies (x64) - ENU: C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\3rdParty\x64\VSTA\expdbgsetup.exe /q
    2012/3/12:05:08:52 HP HP-HP Install Microsoft VSTA Dependencies (x64) - ENU Succeeded
    2012/3/12:05:08:53 HP HP-HP Installing Autodesk® Revit® Architecture 2012: TRANSFORMS="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\x64\en-us\RAC2012\RAC2012.mst;C:\Users\HP\AppData\Local\Temp\_AI9240.tmp\x64\RAC2012\RAC2012-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_Revit_Architecture_2012_English_Win_32-64bit\" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
    2012/3/12:08:49:04 HP HP-HP Install Autodesk® Revit® Architecture 2012 Failed Installation aborted, Result=1603
    2012/3/12:08:49:06 HP HP-HP Rollback Microsoft VSTA Dependencies (x64) - ENU Failed Failure is ignored, Result=1619
    2012/3/12:08:49:08 HP HP-HP Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
    2012/3/12:08:49:09 HP HP-HP Rollback Microsoft Visual C++ 2005 Redistributable (x86) Failed Installation aborted, Result=1619
    Please use plain text.
    Active Member
    gtovar.keithm
    Re: CANNOT install completely
    04-29-2012 02:35 PM in reply to: calliop
    I had the same problem :smileysad:
