Installation & Licensing
Active Member
Message 1 of 7 (175 Views)
Accepted Solution
CANNOT UNSINSTALL MAP 3D 2014
175 Views, 6 Replies
11-13-2013 04:34 AM
HI
I am trying to unstall the Insfrastructure Design Suite Ultimate 2014 and was not able to unsinstall map3d
I want to unsinstall the Suite in order to install it again in Spanish, it was installed in English
THANK YOU VERY MUCH FOR YOUR HELP
*Expert Elite*
DarrenP
Message 2 of 7 (166 Views)
Re: CANNOT UNSINSTALL MAP 3D 2014
11-13-2013 06:08 AM in reply to: pangeaproyectos.es
try running the windows uninstall
through contral panel
Active Member
Message 3 of 7 (159 Views)
11-13-2013 07:57 AM in reply to: DarrenP
hi,
I tried uninstalling from the control panel and I couldn't because Map 3D doesn't appear at software list I received this error when I tried to install the Spanish trial version to activate it
Product Support
Message 4 of 7 (152 Views)
11-13-2013 08:29 AM in reply to: pangeaproyectos.es
pangeaproyectos.es,
Hello. Before you try to install, try to uninstall MAP using the MSfixit tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
This tool is good for uninstalling and cleaning residual traces. It may help here.
Thank you for taking part in our community!
David Dembkoski
Active Member
Message 5 of 7 (136 Views)
11-14-2013 05:19 AM in reply to: dembkod
hello dembkod
I tried using MSfixit and apparently did correctly uninstalling
installed the map 3D 2013 only (6 apps are installed with it)
and now I receive this error, cannot access a acadres.DLL probably while clining up the registers I deleted too much.
I tried importing back the registers to the saved version and the program doesn't open, no message is given,
PROBABLY i AM BACK TO THE STRATING POINT AFTER TWO DAYS OF NIGHTMARE
Active Member
Message 6 of 7 (133 Views)
11-14-2013 05:26 AM in reply to: pangeaproyectos.es
I have openned again FixIt and it says that I have two versions of Map 3D 2014 installed, apparently it didn't uninstall properly since I started encountering this problem when I tried to install the Spanish Trial Version of Map 3D and I had already installed the English Version
Active Member
Message 7 of 7 (122 Views)
11-14-2013 07:25 AM in reply to: pangeaproyectos.es
FINALLY I GOT IT!!!!
MAp 3D 2014 is reinstalled now and I need to know the procedure to change it fron Emglish to Spanish Version
PLease I need help with this
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
