Installation & Licensing
CANNOT UNSINSTALL MAP 3D 2014
6 REPLIES 6
678 Views, 6 Replies
HI
I am trying to unstall the Insfrastructure Design Suite Ultimate 2014 and was not able to unsinstall map3d
I want to unsinstall the Suite in order to install it again in Spanish, it was installed in English
THANK YOU VERY MUCH FOR YOUR HELP
Tags (1)
6 REPLIES 6
DarrenP
try running the windows uninstall
through contral panel
DarrenP
in reply to: DarrenP
hi,
I tried uninstalling from the control panel and I couldn't because Map 3D doesn't appear at software list I received this error when I tried to install the Spanish trial version to activate it
dembkod
pangeaproyectos.es,
Hello. Before you try to install, try to uninstall MAP using the MSfixit tool:
http://support.microsoft.com/mats/Program_Install_and_Uninstall\
This tool is good for uninstalling and cleaning residual traces. It may help here.
Thank you for taking part in our community!
David Dembkoski
in reply to: dembkod
hello dembkod
I tried using MSfixit and apparently did correctly uninstalling
installed the map 3D 2013 only (6 apps are installed with it)
and now I receive this error, cannot access a acadres.DLL probably while clining up the registers I deleted too much.
I tried importing back the registers to the saved version and the program doesn't open, no message is given,
PROBABLY i AM BACK TO THE STRATING POINT AFTER TWO DAYS OF NIGHTMARE
I have openned again FixIt and it says that I have two versions of Map 3D 2014 installed, apparently it didn't uninstall properly since I started encountering this problem when I tried to install the Spanish Trial Version of Map 3D and I had already installed the English Version
FINALLY I GOT IT!!!!
MAp 3D 2014 is reinstalled now and I need to know the procedure to change it fron Emglish to Spanish Version
PLease I need help with this
Administrator Productivity
