Installation & Licensing
Distinguished Contributor
caddman6425nah
Message 1 of 19 (156 Views)
C3D won't start
156 Views, 18 Replies
10-19-2011 07:28 AM
Hi all, I'm running C3D on a 64 bit machine, but the problem is this. It installed just fine, but when I went and started the program, it went through its phases, but...... when the desktop start to open it did as a flash , and the program just bombed and quit. I have no problems with all my other Autodesk programs. Help is surely needed and is wanted at this point, and BTW, TIA Nick
Nick
AEC Design Services
Message 2 of 19 (153 Views)
Re: C3D won't start
10-19-2011 07:48 AM in reply to: caddman6425nah
Here's a few things that should be done when running Autodesk applications which could be causing a problem for you:
  1. Disable UAC (User Account Control) if using Windows 7. To do this go to Start menu, type UAC in the search box and hit ENTER.
  2. Adjust your virtual memory, so that the Initial size is to the recommended size, and the Maximum size is at lease 1000 higher than the recommended.
  3. If you are not an Admin on the machine, have your IT person give you full permissions to the following registry hives:
    HKEY_LOCALMACHINE
    HKEY_CURRENT_USER
    HKEY_CLASSES_ROOT
Hope this helps.
If this resolves your issue, give Kudos or Accept as Solution...
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
caddman6425nah
Message 3 of 19 (149 Views)
Re: C3D won't start
10-19-2011 07:58 AM in reply to: Darin.Green
And what do I do in those registry items
Nick
AEC Design Services
Message 4 of 19 (148 Views)
Re: C3D won't start
10-19-2011 08:02 AM in reply to: caddman6425nah
Try the other one first. If neither of them work for you, have your IT person grant you permissions to those hives.
Darin Green
caddman6425nah
Message 5 of 19 (140 Views)
Re: C3D won't start
10-19-2011 10:56 AM in reply to: Darin.Green
It's only me, I'm the IT person and I have permision to the registry. Now what do you want in the registry for?
Nick
AEC Design Services
caddman6425nah
Message 6 of 19 (136 Views)
Re: C3D won't start
10-19-2011 11:02 AM in reply to: caddman6425nah
And who determine the recomended size, and where do I find it. I'm already at 16 MB now
Nick
AEC Design Services
Message 7 of 19 (127 Views)
Re: C3D won't start
10-19-2011 11:48 AM in reply to: caddman6425nah
Nick,
Try this first... Go to C:\ProgramData\Autodesk\AdLM\ and delete the CascadeInfo.cas file then try running the application again.
Darin Green
caddman6425nah
Message 8 of 19 (124 Views)
Re: C3D won't start
10-19-2011 12:04 PM in reply to: Darin.Green
Didn't work
Nick
AEC Design Services
Message 9 of 19 (123 Views)
Re: C3D won't start
10-19-2011 12:11 PM in reply to: caddman6425nah
Check your virtual memory to make sure it's above the recommended size.
For example, If the Recommended size is 4000, change the Initial Size to 4000 and set the Maximum size to 6000.
To access the virtual memory location, do the following:
Right-click My Computer, choose Properties
If using Windows 7, select the "Advanced system settings" link on the left of the System page
System Properties Dialog will open
Go to the Advanced tab and click Settings under Performance
Performance Options dialog will open
Go to the Advanced tab, and click the Change button located at the bottom of the dialog
Darin Green
caddman6425nah
Message 10 of 19 (118 Views)
Re: C3D won't start
10-19-2011 12:44 PM in reply to: Darin.Green
Darin, If I ask what you want me to do in the registry, I would conclude that I have done all the other things. So I just bumped up the virtual memory again. Nothing! So again I ask, what do I do in the registry and why?
Nick
AEC Design Services
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
