• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    *Cravero, Pierpaolo
    C-Dilla of AutoCAD 2000i crashes peer to peer networks !!!!!!!!!!!!!!!!
    175 Views, 6 Replies
    01-11-2001 12:10 AM
    I have installed a little peer to peer network like this:
    1 computer running Windows 2000 sp1, Mechanical Desktop 5 sp2 and Inventor 3
    1 computer running Windows 98 Second Edition and AutoCAD Mechanical 2000i
    sp2
    1 computer running Windows 95 and AutoCAD LT 97
    The problem is this:
    The network works well but when I launch any application (Word, Excel,
    AutoCAD) on one computer and try to open a file located on a machine that is
    running a C-Dilla based application I receive the message: "The requested
    file is no more present or the network connection is no more disposable",
    then the 2 computers crash and I have to reboot both systems.
    Nothing of this happens if I open a file that is located on a machine that
    is not running any C-Dilla based application.
    Does anyone knows more about this very serious problem ?
    Thank you and sorry for my english.
    Pierpaolo Cravero.
    Please use plain text.
    *Support\, Autodesk
    Re: C-Dilla of AutoCAD 2000i crashes peer to peer networks !!!!!!!!!!!!!!!!
    01-11-2001 12:27 AM in reply to: *Cravero, Pierpaolo
    Ciao Pierpaolo,
    European Product Support have received several reports of this behaviour
    recently. I am currently tracking the issue and working with development to
    ascertain the cause. I'm sorry I don't have a workaround at present. Please
    bear with us.
    Simon Gillis
    Product Support Analyst
    AMG Product Support UK
    Worldwide Support & Services, Autodesk
    "Pierpaolo Cravero" wrote in message
    news:C449AD60B394D16A8FEA52B4DE78E762@in.WebX.SaUCah8kaAW...
    3
    > sp2
    is
    that
    > Pierpaolo Cravero.
    *Moses, Torsten
    01-11-2001 12:48 AM in reply to: *Cravero, Pierpaolo
    Hi, Pierpaolo,
    I'm sorry not to be able to help - but I have similar experiences with
    C-Dilla.
    On Win2000 I use straight Acad2000i with C_Dilla and it works - first.
    When I open TaskManager, I see "CDNTSERVICE.EXE" (or similar - the
    C-Dilla Service is ment) and "CDxx64.EXE" (another part of C-Dilla).
    When Acad2000i is running, and I then run a DOS-based program (inside
    virtual DOS-box), the machine freezes, and the speaker is "singing"
    (beep-beep-beep....).
    At the TaskManager there is a new entry:
    ntvdm (NT virtual DOS machine - the DOS box)
    wow.exe (WindowOnWindow - emulation for 16-Bit window code)
    CDxx16.exe (another C-Dilla part that seems to cause the crash)
    It seems, that C-Dilla system uses incompatible, old 16 bit DOS/WIN code;
    may be, this same reason causes your mysterious failures ... ?
    If I start them in reverse order (DOS-based program first), everything is
    fine.
    This behaviour could be constantly reproduced on my machine !
    Greetings and I hope, someone could help you (and me)
    Torsten Moses
    *Hetzel, Simon
    01-16-2001 07:43 AM in reply to: *Cravero, Pierpaolo
    I also have this problem with a Windows 2000 and Windows NT machine in a
    peer-to-peer network.
    Simon
    *Hetzel, Simon
    Re:
    01-18-2001 12:38 AM in reply to: *Cravero, Pierpaolo
    "Torsten Moses" wrote in message
    news:smileyvery-happy:3E888A3115EB57E96104BDEC1F91168@in.WebX.SaUCah8kaAW...
    I have the same problem as Pierpaolo but not as you
    So far a DOS box seems to work fine for me if opened before or after A2ki.
    Perhaps there is something else happening? Is it a **program** running in a
    DOS box that stops A2ki or is a command-prompt window alone sufficient?
    Simon
    *Hetzel, Simon
    Re:
    01-18-2001 01:05 AM in reply to: *Cravero, Pierpaolo
    "Simon Gillis (Autodesk Support)" wrote in message
    news:0D4DCAFD3FB4A6D91B996AD09506E0E2@in.WebX.SaUCah8kaAW...
    to
    Please
    > bear with us.
    Do you have any more details about what triggers this problem? I'm
    suffering from the same symptoms as Pierpaolo but cannot repeatedly
    reproduce the fault.
    In my case the problem also seems to be associated with one machine opening
    files shared from another whilst A2ki is open on the machine that is hosting
    the file shares. - but not always....
    Particularly problematic are the occasions when my Windows 2000 laptop
    machine is synchronising (for offline use) the shares on my Windows NT
    desktop. (The laptop was previously set to do this whenever it was idle).
    Simon
    *Moses, Torsten
    Re:
    01-18-2001 07:41 PM in reply to: *Cravero, Pierpaolo
    Hi, Simon,
    this process happens :
    Sometimes I use good, old Norton Commander, that runs in a DOS box.
    When I start the NC/DOS first, Acad+C-Dilla crashes with 16Bit-conflicts,
    if I start Acad first, everything works well ...
    I use similar system configuration win Win98SE, NT40 and Win2000 -
    never had any compatibility problems with DOS box software (the DOS box
    is encapsulated from the rest of the system - this is the sense of DOS box)
    It seems, that C-Dilla is partially programmed with 16-Bit DOS/WIN code,
    and this is the reasons for my crashes ...
    What I wanted, is to give you some hints about C-Dilla - nobody could
    estimate
    the further side-effects of that 16-BIT problem of C-Dilla. For my machine,
    it crashes
    with any other open DOS box, for other machines ... ???
    Many Greetings
    Torsten Moses
