I have installed BDS Prem 2013 on two computers connecting to license server with two available licenses. Those work fine.
I just installed on another computer and when authenicating it says that the Serial # is not valid. It worked on the other computers and I am looking right at the number on the box. It is a 30 day trial mode right now.
What is the solution?
gb
Is the third computer able to access the Internet so that it may authenicate the serial number?
Are you sure the install radio button is set to Network and not Standalone above the serial number input?
if you installed as a trial its standalone
if you need to install as network this will require a uninstall/reinstall
DarrenP
