EVERY autodesk product i try to use, it gives me a blank activation screen (attached picture)
i have a 3 year student license with autodesk but i am unable to activate my products with this license.
this has been happening since november, and i've tried it with both maya and 3dsmax 2011 64 bit.
i have windows 7 64 bit.
i even tried running 2010 32bit versions of the products and i still get the same blank activation screen.
i've contacted autodesk but they are unable to help with this issue.
This issue is typically related to the operating systems corrupted jscript.dll file.
Please try this : http://usa.autodesk.com/getdoc/id=TS1053941
Or
Re-register Jscript.dll file :
1. Click Start, and then click Run.
2. In the Open box, type regsvr32 jscript.dll, and then click OK.
3. Click OK.
i've tried that a while ago and it didn't seem to fix the problem.
here is what i get after i fail to activate maya:
Please check this thread - http://forums.autodesk.com/t5/Installation-Licensing/Maya-2011-Trial-Installation-Error/td-p/2675334...
I am also having this problem I've tried everything suggested and it didn't work for me 😞 I've been trying to activate 3ds max and it lets me try it, but when I try to activate it it shows me the blank screen with the 2 radio buttons.
Please check this thread out for Blank Activation screen
http://forums.autodesk.com/t5/Installation-Licensing/Blank-Activation-Screen/td-p/2862508
Cheers
this link which u provide is not working
and
I am also having this problem I've tried everything suggested and it didn't work for me I've been trying to activate 3ds max and it lets me try it, but when I try to activate it it shows me the blank screen with the 2 radio buttons.
i m tired now to doing this all suggestion i completly tryed all suggestion not only in my laptop even i tryed in my friend computer, lapto too. but all fail not working at all.how it could be
i dont understand y a lot of people can get same problem i guess this this problem of autodesk program
not in our setting.
i request if u really want to help us u can upload video tutorial
Thanks & Best Regard
<!-- saved from url=(0016)http://localhost -->
use this into all html file 100% works for me
Look these image
http://forums.autodesk.com/autodesk/attachments/autodesk/24/29298/1/picture%201.gif
http://forums.autodesk.com/autodesk/attachments/autodesk/24/29298/2/picture%202.gif
http://forums.autodesk.com/autodesk/attachments/autodesk/24/29298/4/picture%203.gif
For more information on this known Autodesk Support Knowledge Base article, please follow this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6404339&linkID=9240617
Additional discussion about this issue can be found here:
None of these comments work!! There obviously is no solution...What a heap of rubbish. It's a fricking website adress which doesn't load! Autodesk sort yourself out!
