• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    DCulver
    Blank Register Today Screen
    10899 Views, 12 Replies
    08-03-2010 02:41 PM
    I installed AutoCAD LT 2010 on a new Windows 7 64 bit machine.  When I try to import the license from the License Transfer Utility, I get the Register Today screen, but it's blank.  Any ideas?
    Dennis Culver
    Please use plain text.
    Charles_Shade
    Re: Blank Register Today Screen
    08-03-2010 03:02 PM in reply to: DCulver
    http://forums.autodesk.com/t5/Installation-Licensing/bd-p/24
    Regards, Charles Shade             Win8 FAQ
    CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
    Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
    Product Support
    08-04-2010 01:01 AM in reply to: Charles_Shade
    Some more pointers.
    http://forums.autodesk.com/t5/Installation-Licensing/Civil-3d-2010-Home-License-Use-Activation-Issue...
    http://www.cadtutor.net/forum/showthread.php?48750-Problem-with-Autocad-2011
    if
    regsvr32 jscript.dll doesnt help
    you could do
    regsvr32 /u jscript.dll
     first then
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    For more tips & tricks: http://upandready.typepad.com
    Hashim Mundol
    Autodesk Product Support
    New Member
    olthoff
    09-12-2010 03:25 AM in reply to: DCulver
    Awesome Hashim,
    Your last option fixed my licensing crashing. Thanks a lot.
    New Member
    005ADPDF0008
    11-08-2010 05:54 AM in reply to: olthoff
    say... im using windows 7 32bit, and i've been getting the same problem. and all these solutions have been not working effectively on me. any idea?
    New Member
    79503
    01-28-2011 05:21 AM in reply to: hashim.mundol
    Dear hashim,
    I download autocad 2010, but i get (after licence epired) the message of:
    activate
    buy
    run
    Run is grey, and i cant click it, and when i click activate and buy, it gives the 'register today' message.
    Could you please mail me what the solution was? this because the forum-maker said ur last option helped, but the site doesnt work anymore.
    Please mail me at: jimmybos_1@hotmail.com
    Really thx in advance!
    Jimmy
    Product Support
    01-28-2011 07:27 AM in reply to: 79503
    DId you try Autocad 2011 ?
    Hashim Mundol
    Product Support
    04-20-2011 07:45 AM in reply to: hashim.mundol
    I ran into a similar issue with a client recently and I wanted to get this procedure out into the groups.  Other processes I tried did not work, but this one is a slight variation on previous methods and worked.
    Basically, you make sure you run the command window as an Administrator and unregister and register two dlls. Here is the process that worked for me:
    1.)   Ensure that all Autodesk applications are closed.
    2.)   In the search/run bar at the bottom of the Windows Start menu, type CMD but do *not* press Enter.  The menu will change to a search results page, displaying cmd.exe at the top of the list.
    3.)   Right-click on cmd.exe at the top of the list and choose Run as Administrator from the context menu that appears.
    4.)   If prompted whether to allow the program to make changes to Windows, click Yes; a DOS prompt window will appear.
    5.)   At the command prompt, enter regsvr32 /u jscript.dll to unregister
    6.)   At the command prompt, enter regsvr32 /u vbscript.dll to unregister
    7.)   At the command prompt, enter regsvr32 jscript.dll to register
    8.)   At the command prompt, enter regsvr32 vbscript.dll to register
    9.)   Reboot your machine.
    10.) Retest the registration.
    Hope this helps!
    Thank you for participating in our community!
    David Dembkoski
    Product Support Specialist
    New Member
    xman9
    12-09-2011 08:57 AM in reply to: dembkod
    Does not work
    Product Support
    12-22-2011 04:55 AM in reply to: xman9
    If you have IE9, please uninstall it.
    Hashim Mundol
