Installation & Licensing
Blank Register Today Screen
14 REPLIES 14
Message 1 of 15
13314 Views, 14 Replies
I installed AutoCAD LT 2010 on a new Windows 7 64 bit machine.  When I try to import the license from the License Transfer Utility, I get the Register Today screen, but it's blank.  Any ideas?
Dennis Culver
14 REPLIES 14
Message 2 of 15
Charles_Shade
Message 3 of 15
Some more pointers.
http://forums.autodesk.com/t5/Installation-Licensing/Civil-3d-2010-Home-License-Use-Activation-Issue...
http://www.cadtutor.net/forum/showthread.php?48750-Problem-with-Autocad-2011
if
regsvr32 jscript.dll doesnt help
you could do
regsvr32 /u jscript.dll
 first then
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
Message 4 of 15
olthoff
Awesome Hashim,
Your last option fixed my licensing crashing. Thanks a lot.
Message 5 of 15
in reply to: olthoff
say... im using windows 7 32bit, and i've been getting the same problem. and all these solutions have been not working effectively on me. any idea?
Message 6 of 15
in reply to: hashim.mundol
Dear hashim,
I download autocad 2010, but i get (after licence epired) the message of:
activate
buy
run
Run is grey, and i cant click it, and when i click activate and buy, it gives the 'register today' message.
Could you please mail me what the solution was? this because the forum-maker said ur last option helped, but the site doesnt work anymore.
Please mail me at: jimmybos_1@hotmail.com
Really thx in advance!
Jimmy
Message 7 of 15
hashim.mundol
DId you try Autocad 2011 ?
Hashim Mundol
Autodesk, Inc.
Message 8 of 15
dembkod
I ran into a similar issue with a client recently and I wanted to get this procedure out into the groups.  Other processes I tried did not work, but this one is a slight variation on previous methods and worked.
Basically, you make sure you run the command window as an Administrator and unregister and register two dlls. Here is the process that worked for me:
1.)   Ensure that all Autodesk applications are closed.
2.)   In the search/run bar at the bottom of the Windows Start menu, type CMD but do *not* press Enter.  The menu will change to a search results page, displaying cmd.exe at the top of the list.
3.)   Right-click on cmd.exe at the top of the list and choose Run as Administrator from the context menu that appears.
4.)   If prompted whether to allow the program to make changes to Windows, click Yes; a DOS prompt window will appear.
5.)   At the command prompt, enter regsvr32 /u jscript.dll to unregister
6.)   At the command prompt, enter regsvr32 /u vbscript.dll to unregister
7.)   At the command prompt, enter regsvr32 jscript.dll to register
8.)   At the command prompt, enter regsvr32 vbscript.dll to register
9.)   Reboot your machine.
10.) Retest the registration.
Hope this helps!
Thank you for participating in our community!
David Dembkoski
Product Support Specialist
David Dembkoski
Message 9 of 15
xman9
in reply to: dembkod
Does not work
Message 10 of 15
hashim.mundol
in reply to: xman9
If you have IE9, please uninstall it.
Hashim Mundol
Autodesk, Inc.
Message 11 of 15
Oh god thank you, finally a solution that worked! Smiley Very Happy
I've been struggling for several days with all kinds of solutions, from both this forum and others. I'm running a windows 7, 64 bit system from dell.
Cheers!
Message 12 of 15
Just another possibility for others that may find this post.
I have seen IE9 affect some installs. Sometimes this can cause a blank register screen. Rolling back to IE8 can help, but it is not always a simple process.
1.)    Log in to Windows and go to the Control Panel.
2.)    Access Programs and Features option
3.)    Click “Turn Windows features on or off”.
4.)    Uncheck the Internet Explorer 9 box
5.)    Click “OK” and the system will process.
6.)    After this completes, shut the machine down completely and restart.
7.)    When windows boots click the Windows Start button
8.)    Access the Run box and inside, type CMD.exe but do not press [Enter].
9.)    Move your cursor over the CMD.exe icon above and right-click
10.) Click Run as an Administrator
11.) In this window copy and right-click paste the following text:
FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-*9.*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"
12.) Press Enter and the process will run. You may get errors. Accept them.
13.) After this completes (may take a few minutes and look like nothing is happening- wait!) run the same command again. (2x total)
14.) After this is through, go to the Control Panel.
15.) Access Programs and Features option
16.) Click "Turn Windows features on or off"
17.) Internet Explorer 8 should be present, make sure it is checked
18.) Close the window and try to run and activate the software
Thank you for taking part in our community!
David Dembkoski
David Dembkoski
Message 13 of 15
This worked so well. Completely fixed my issue
Message 14 of 15
hi there
iam getting same pb, blank screen with 2 radio buttons...nothing worked at the moment, havent tried uninstalling explorer 10 i use though
try to activate the Autocad 2011 on windows 7 64 bitt
pls Autodesk help
regards
Message 15 of 15
joane.bonghanoy
in reply to: a_budusan
Hi a_budusan,
If the error you encountered is the same one as on this link, please follow the troubleshooting steps provided.
Let me know if it still didn't work out for you.
Joane Bonghanoy
Administrator Productivity
