Installation & Licensing
New Member
Message 121 of 188 (2,612 Views)
Re: Blank Activation Screen
05-06-2013 10:08 AM in reply to: gmijares
This is the real solution:
1. Ensure that all Autodesk applications are closed.
2. In the search/run bar at the bottom of the Windows Start menu, type CMD but do *not* press Enter. The menu will change to a search results page, displaying cmd.exe at the top of the list.
3. Right-click on cmd.exe at the top of the list and choose Run as Administrator from the context menu that appears.
4. If prompted whether to allow the program to make changes to Windows, click Yes; a DOS prompt window will appear.
5. At the command prompt, enter regsvr32 /u jscript.dll to unregister
6. At the command prompt, enter regsvr32 /u vbscript.dll to unregister
7. At the command prompt, enter regsvr32 jscript.dll to register
8. At the command prompt, enter regsvr32 vbscript.dll to register
9. Reboot your machine.
10. Retest the registration.
JarretDD
Message 122 of 188 (2,604 Views)
05-06-2013 12:39 PM in reply to: b_federico
So guys, it's been what-- two, three years since I found how to fix this by editing the RTBeginreg html? Anyway, I thought I'd update to 3dsmax 2013 and lo and behold I get this same problem, white activation screen. Fixed it in the same fashion!
Member
Message 123 of 188 (2,594 Views)
05-06-2013 05:36 PM in reply to: b_federico
Thanks you very much for your helping, i will try to do follow your way and will inform you.
Best Regard,
New Member
Message 124 of 188 (2,430 Views)
05-21-2013 02:07 PM in reply to: govy86
what happend if it diddnt work!!!! still white!
Active Member
miroslav_s
Message 125 of 188 (2,390 Views)
05-26-2013 09:04 AM in reply to: gmijares
I am going crazy here!. I too got a white screen. Trying to activate autocad mep 2014 on windows 8 pro with internet explorer 10. So if you have the solution please help. The strange thing is that I did install and activate the Autocad 2014 but get the white screen when I try to activate autocad mep 2014.
Thanks in advance and best regard to you all!
MS
New Member
Message 126 of 188 (2,319 Views)
05-30-2013 11:30 AM in reply to: miroslav_s
I did all the things listed here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=6404339&siteID=123112 but i am still unable to make my Activation Screen working. Problem with Inventor 2014 on windows 7.
Active Member
miroslav_s
Message 127 of 188 (2,310 Views)
05-30-2013 02:01 PM in reply to: b_federico
Finally! I just uninstalled autocad from my computer, Deleted all files regarding autocad from my comp and reinstalled everything. Now, autocad is working just fine. No white or blank screen during activation. Thank you lord!
Best regards to you all
MS
New Member
Message 128 of 188 (2,292 Views)
05-31-2013 02:49 AM in reply to: b_federico
Great.... I finally managed to see my request code after hours of fight with that blank screen. I used online manual registration only to find out, that i can t activate my programm because of the error 11 - activation code for my software has been already sent maximum times. What!?! It seems that I have been generating that stupid code everytime i opened my blank screen of activation. Is there anything i can do with it?
camilo.lemos
Message 129 of 188 (2,287 Views)
05-31-2013 03:03 AM in reply to: dziopa
Hi dziopa,
Can you please send me your serial number and request code via Private Message (click on my camilo.lemos profile name and then on Send This User a Private Message)?
Thank you
Camilo Lemos
New Member
Message 130 of 188 (2,053 Views)
07-04-2013 10:25 PM in reply to: Xrispie
Thaks a lot mister, that really helped me, it is such a simple solution... Thanks  a MILLION but it stuck after that
i have selected connect to internet, then the next page is blank
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with Us
Twitter
Pinterest
Blog
Youtube
