• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    skavengur
    Re: Blank Activation Screen
    07-13-2011 06:32 PM in reply to: JarretDD
    Thanks, had the blank activation screen with Max 2012 and this solved it! :smileyhappy:
    Please use plain text.
    New Member
    anakmuda
    07-18-2011 12:08 PM in reply to: skavengur
    hi there, i found this helpful tool thats 100% works,
    link here>sIBL_GUI_For_3dsMax
     download n follow the step on read me file.
    but make sure u dont change the RTBeginReg script.
    hv nice day.
    do catch me on ym: azazielannamirun
    New Member
    kreat1f
    08-14-2011 01:07 AM in reply to: JarretDD
    tq so much dude. it very helpful n work for my computer. .
    Active Member
    08-19-2011 11:13 AM in reply to: govy86
    well done! this fixed our problem - thanks much!  Tim from https://basepin.com
    New Member
    aalza3eem
    08-22-2011 07:36 AM in reply to: ranjeet7
    Same here
    "everytime i hit the save button it said the access to the file is denied"
    what is the solution.
    The steps fixed the black, but the last step is where it gets the mentioned message:
    'line 158
    access to the file is denied'
    New Member
    pbronkow
    08-23-2011 11:14 PM in reply to: aalza3eem
    Like a lot of the other messages said ....add
    <!-- saved from url=(0016)http://localhost -->
    into the RT files......start with RTBeginReg.html    put ^^ right after the first line and save, if you cannot save, close the file, right click, go to properties, security, EDIT ADMINISTRATORS and click the box for FULL CONTROL, then reopen the file add the above link and save it....do this to the next RT file in line if it doesnt work....i got to about the 4th RT file in line before it allowed me to register, after that it still gave me an script error message on the last page where i had to hit FINISH but it did the job.......
    happend in Revit, so should be the same for all since theyre all autodesk products i believe
    New Member
    rpmpowered
    09-01-2011 07:40 AM in reply to: pbronkow
    i have this problem too, here is ans screenshoot, whre i put that? in that blue zone?
    New Member
    rpmpowered
    09-18-2011 08:49 AM in reply to: rpmpowered
    i saved file whit that <!-- saved from url=(0016)http://localhost --> right below httml and i have same problem, can anyone help me
    New Member
    speck_3
    09-21-2011 07:50 PM in reply to: Zed90
    I was having the same problem, the way i found around it was to firstly open the file, add in the suggested line then instead of just trying to save over the top of the existing file I saved the file(s) onto my desktop and then after I had edited all the files I needed to, I just went back and did a copy and paste, overwriting all previous copies and hey presto no problems.
    New Member
    13579007
    10-16-2011 07:43 AM in reply to: govy86
    Thanks dejanxp very much!
