• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    JarretDD
    Re: Blank Activation Screen
    05-13-2011 06:15 PM in reply to: avto
    Thanks for listing all those solutions. Took you guys a while, but It is sure to help a lot of people.
    Please use plain text.
    New Member
    hausiusi
    05-15-2011 11:54 AM in reply to: JJkutzer
    Thanks a lot. yout Advice was wonderful (Y).
    New Member
    antonarap
    05-30-2011 12:56 PM in reply to: gmijares
    OK this is what worked for me:
    Although I have a 64 bit version, I used the Command Prompt to navigate to directory C:\Windows\System32 I typed regsvr32 jscript.dll and  regsvr32 vbscript.dll. There is a space character between the comand (regsvr32) and the archive name (jscript.dll for example).
    In order to navigate in a certeen directory with the command prompt use cd.. to move une directory up and cd NAME OF DIRECTORY to move one directory down (example: cd windows to move from c: to c:\windows, cd.. to move from c:\windows to c:smileyhappy:
    This way the activation screen was displayed correctly.
    New Member
    Petrit10
    06-18-2011 08:29 AM in reply to: govy86
    Thank you for helping us.I activated with succes but something have done wrong because when click two times the icon the programm doesn't open.Please ,help me to get a choise.
    New Member
    danblukk
    06-23-2011 05:48 PM in reply to: gmijares
    My 3D max 2011 worked fine unitil i had to format my pc and reinstall everything now i get the white screen licence thing. But mine sounds a little different to the rest. I get a small plane white box, dont even get the chane to click activate, but get this, if I open task manager and end the task, the activator windows comes up, can click activate and then it all works as normal, all radio buttons show, can click continue to activate my code but then the comuter gets on with the end task request and closes it. How annoying is that. Tried all solutions, mutiple browsers, reg edits, cmd prompts, nothing works.
    Any advice anyone?
    JarretDD
    06-25-2011 07:56 PM in reply to: danblukk
    Did you try the adding-the-tag-to-the-html solution on the first page?
    Strange how you can almost continue with the activation is windows thinks the task has ended, but initially it is still blocked, for some reason. Since you've tried all the other solutions, adding the <!-- saved from url=(0016)http://localhost --> tag might help, as described on page 1 here.
    New Member
    eurgbp2011
    06-26-2011 04:26 AM in reply to: gmijares
    same problem on firefox 4 and win7 x64
    New Member
    mdm6533
    Re: Blank Activation Screen -<{ THIS WORKS }>-
    06-29-2011 05:18 PM in reply to: dejanxp
         Hey, just wanted to give a big thanks to ya for this help!  I know nothing of HTML scripting or editing, but followed your instructions (and thanks for the pics, definitely helped since I'm a visual learner), and on the next try to activate, all went well and was done in seconds:smileyvery-happy:  Can't tell ya how relieved I am now!
    P.S.-  Running Win XP SP3 with Internet Explorer
    New Member
    whiterabbit77
    07-07-2011 06:51 AM in reply to: gmijares
    hi all,
    i'm getting the same problem but i'm using mozilla firefox, any instructions on how to fix it within that?
    cheers
    New Member
    Th10
    07-08-2011 04:32 AM in reply to: JJkutzer
    thhaaaaaaaaaaaaankkk youuu verry verry much your way work like magic but you know there is one little problem . it's not "'HKEY_CURRENT_USER/Software/Microsoft/Internet Settings/Zones' it's "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings\Zones"
    at least that's what work for me but like you said just delete file "L" and it woooooooooooorkkkkkk
    thaaank youu veryy veryyy verryyy much
    and for more help use that link
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240617&id=6404339&siteID=123112
