Installation & Licensing
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Blank Activation Screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In early Dec 2010 I downloaded AutoCAD 2011 (I already had the 2010 version). When I opened it, a screen appeared with the option to 'TRY' or 'ACTIVATE'. When I clicked on Activate the next screen appeared but it was blank except for 2 radio buttons without any text attached. Supposedly, I have to get a request code from that screen to activate but obviously I can't.
Does anyone have any suggestions for this particular problem?
Re: Blank Activation Screen
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I am having the same issue with AutoCad 2011 LT. I havent been able to get any help on this matter. Please someone Help Us!
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I've had this problem for the last two days, after my student licence expired.
The steps described in http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Please, this issue needs attention.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I solved it... here's the REAL problem.
Your computer is blocking activex controls.
The first solution is to go into Internet explorer>Tools>internet options or control panel > internet options.
Under the security tab, choose internet zone. Click custom level, and enable the options pertaining to ActiveX ontrols ans java scripting. Then you SHOULD be able to view the controls that were blocked out in the blank activation screen.
This didn't work for me, but it works for others, so I hear.
The second solution for me was to enter the C:\Program Files\Common Files\Autodesk Shared\AdLM\R1\en-US\Webdepot folder, which is where the registry HTMLs are stored. These are the pages that the blank screen shows on.
Open the RTBeginReg.html in a text editor like notepad. Add the following line of code below the <html> line.
<!-- saved from url=(0016)http://localhost -->
This marks the page as SAFE. Save and you should be able to enter your code and stuff.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
wow... great! the second one works, but there's still one problems. when i confirm the activation, i've got some script errors :/ and it appears all the time whenever i click anything. any advice?
thank you ![]()
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
AutoCAD 2011 on Windows XP.. Blank Activation Screen
sorry to trouble you all but neither of those options have worked for me .. going through Regedit or through ActiveX scripting
any idesa ??
not even through the link to the html's in the registry ...
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
hello friend
if system ms vindows sries;
create new admin accont to system => login to admin accont => start activation license maneger ![]()
god bye
Türkiyeden selamlar
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
A quick and easy way to fix this not with just AutoCad but if you have the same problem with other pro grams is, open 'run' command, type in 'regedit' go to 'HKEY_CURRENT_USER, Software, Microsoft, Internet Settings, Zones' you will see under Zones are six files each named 'L' '0' '1' '2' '3' '4', delete the file named 'L', that is the activex problem, you can uninstall it from your PC but these are "parasite" files that stay in the system. Problem solved quick and easy![]()
